Problem when turning/braking! Help me out!
Hello,
Lately I've been having some problems when I brake or turn. The car feels as if I'm hitting slightly the brakes when I make a turn
. Also, when I start braking from a high speed it feels all shaky in the front...
Can anyone help me out?
tell me more about the cars parts; suspension, brakes, wheels/tires, bushings, bars, etc.
Shaking - do you mean pulsing in the rotors. If so, you have pad material transfer.
Things to check:
1. Lug nut torque. I prefer 100 ft/lbs. Spec is 80.
2. Rotor run out. Need to take to a shop for this unless you have a run out gauge. Look for hot spots on the rotor surface. To fix, machine the surface.
3. Check pads for cracks and uneven wear.
And if you are not comfortable doing any of that - go to a shop.
Things to check:
)The car also does a humming like sound and it gets louder as I go faster... you can really hear it on the highway
Things to check:
Things to check:
facing the same problem. just put new pads(EBC yellowstuff) on my stock calipers, only one (front passenger side) of them makes this whiny noise. rotors were on the car for a while(im guessing about a yr or so), and they are slotted powerslotts. weird...
003-EVO
22
May 22, 2017 03:54 PM
pcguru2000
Lancer Troubleshooting
May 10, 2013 06:43 AM
bdonIX
Dec 18, 2012 02:22 AM
Jozino
Nov 14, 2011 02:00 PM
