Very loud high pitched squeel when braking & turning left only
Hello fellow EVO enthusiasts !
Was hoping one of you's would help me out on this one if possible..
Problem:
When turning left only & applying the brakes, I get very very bad high pitched metal on metal brake squeal.
I am running projectmu slotted rotors with bendix pads
This afternoon, I am going to inspect the bearing & backing plate to see whether it is making contact with the rotor.
Any other inputs you guys would recommend checking ?
thanks in advance
Problem:
thanks in advance
003-EVO (Mar 1, 2017)
shims that came with the bendix pads
https://automotivesuperstore.com.au/...sRTBoCE3Hw_wcB
greased up all sliders, etc.
but when steering wheel is straight, does not squeel once brakes are heated up.
only squeels when turning left & braking...
Will chuck the OEM shims on & will let you know..
reason i think it could be something else other than the shims is when i full lock left aswell at a slow speed such as rolling out of a driveway, I hear a very light metal on metal grinding noise coming from the front left.
What I will do is check the bearings for play, if no play, ill rip the wheels off & put OEM shims in..
Hopefully that will get rid of that ugly sound !
You wont always find "play". I just did my front bearing for the same type of concern. No wheel play, wiered noises louder when braking and turning into garage. Due to worn wheel bearing. Removed hubs and the right side was completely in pieces and the bearings were dry and blueing from extreme heat.
One of the youtube mechanics (he has a channel) claims you can always find a bad wheel bearing by spinning the wheel and feeling for vibration in the spring. I've seen a lot of things with wheel bearing and therefore doubt that this is a sure thing. Still, maybe, worth a try.
ok so I managed to have a better look at it after work
Defiantly seems like it is brake related to me now. No play in either front wheels & the squeal defiantly sounds like it could be the pads/shims I am running.
Put OEM shims in. Nothing changed, still squeal.
Sound is exactly like this:
Although it seems like it only makes it when brakes are usually heated up & applying brake while turning (seemed like it made it turning either right or left when I drove yesterday)
when braking in a straight line for some odd reasons its not that bad at all..
I previously had project mu HC+ pads & had very bad squeal with them everywhere, so changed them to the bendix GCT's.. been driving for about 1000ks since replaced them to resurface the rotor from the previous pads
