Tire Rack Bilstien ??
Old Jan 10, 2011 | 05:20 PM
cracovia_2006's Avatar
Got a question about Bilstien sold by Tire Rack. Are those the same shock as MR Bilstien ?? If not what is the main difference ?? I check some web pages and i found out that MR shock part no. is different then Tire Rack shock. From i was told they should be the same but I'm confused now. Thanks for your input
Old Jan 10, 2011 | 05:21 PM
GTWORX.com's Avatar
They're different....they're the Bilstein HDs. Similar though.
We have them in stock.
- Andrew
Old Jan 10, 2011 | 05:23 PM
How different are they ?? Is it gonna be much difference between them in performance way ?? and if i pair those with stock evo 9 GSR springs will it work ??
Old Jan 10, 2011 | 05:27 PM
GTWORX.com's Avatar
Very very similar. Maybe 5% firmer, if that.
By different I just meant that they come direct from Bilstein. Also a lot cheaper.
https://www.evolutionm.net/forums/ev...ics-carol.html
It will work nicely with stock springs.
- Andrew
Old Jan 10, 2011 | 06:08 PM
I found an info that GSR springs and MR springs are rated the same. Is that true ??
Old Jan 11, 2011 | 11:32 AM
Neal@tirerack's Avatar
A bit stiffer than the oe. Bilstein does goofy stuff with their part numbers also. If they change even the smallest thing about them, type of bolt used, color change on bracket, etc, they change the part #.
Old Jan 11, 2011 | 05:58 PM
McDougal's Avatar
Neal, will you pm me with your price for a set of four.
evo8john
17
Aug 30, 2010 03:46 PM
adamturbo
Feb 11, 2010 04:27 AM
avo3vom
Oct 18, 2008 07:59 PM
The Nothing
Jan 13, 2008 08:58 PM
silvrevo
12
Jun 13, 2006 02:28 PM
