Tire / Wheel Fitment Questions
Old Apr 27, 2017, 06:22 AM
  #3391
Received 1,384 Likes on 1,317 Posts
Originally Posted by gsrboi80
Looking for the right size tire for a set of street wheels I have. 18x9 +25 Rota G-force. I confirmed the fitment and get no rubbing on the 225 45 18 that were mounted when I got them, confirmed on coilovers and MR Bilsteins with Swifts. They also clear the front Brembo without issue.
Tires maybe have 2k on them, I never intended to run that tire anyway but were included in the sale however funny thing is though they don't look stretched on the wheel at all, they def don't corner on their sidewalls like other silliness I've seen, but either way they're cracking something terrible prob from not using them or **** federal tires who knows.
Not looking to do much if any fender work at all the rear quarters in my car are factory flawless and I don't know or trust anyone within 500 miles of here to even think about it.
That said I'd like to fit a 255/35 but in reading and measuring it may not work, however a 245/35... Thoughts? Minus?
Car is on a new set of coilovers now and also new aftermarket adjustable LCA's
Ran the following no.s = 18x9 +25 running the min width allowed on a 9" wheel. 235/40/18. This would be your best bet.
The issue is with the +25 which is a very aggressive offset, although the 9" wheel helps vs a 9.5"
You will need to have a rear fender roll to make this fit w/out any chance of rubbing. Is there any chance you will change your mind on rolling the rears?
You can always do a test fit so you can see what Im noting here. Again, +25 is tough to correctly fit w/out rub or out of spec rear camber settings
If you do a roll you can possibly go up one size to a 245/40 or a 245/35. At this width, you are getting very close to needing a rear fender pull
Joe
gsrboi80 (Apr 27, 2017)
Old Apr 27, 2017, 07:18 PM
  #3392
gsrboi80's Avatar
Thank you for your input, greatly appreciated sir. I guess I wouldn't be opposed to having that inner lip flattened up a little bit, but fear this would create a little "U" shaped channel where water can now sit, so maybe cut a little bit off the inner lip, As long as that new raw metal edge is coated and sealed from elements. Then their remains finding someone reputable in the NE that can perform the work properly and professionally.
Well I definitely have a couple options now.
Thank You Again!!
MinusPrevious (Apr 27, 2017)
Old Apr 27, 2017, 07:43 PM
  #3393
Thank You Again!!
Happy to help
With my body work, we did only a 3/4 roll & the rest was done w/a rear fender pull. Totally understand about not having a pocket there where corrosion will burn the metal. My EvO doesnt see any wet weather so Im not affected
Some shops dont like to cut the rears due to loosing the double metal thickness & potentially causing a ripple. But if its done right it will offer more clearance & prevent a debris trough
Old Apr 29, 2017, 08:59 PM
  #3394
LukeCabrera7's Avatar
Anybody have any experience with CE28N Time Attacks? I was thinking of getting a friend's 18" x 9.5" +34 to go with 245/35/R18 tires. I want to keep the car as stop as possible so no fender rolling or spacers. Will it clear the brakes and no fender rubbing? Btw I have Endless 4-pot calipers all around.
Old Apr 30, 2017, 05:20 AM
  #3395
Great wheel & very good size & offset for the EvO rear fender. But, to be safe, I would still recommend a rear fender roll
Fitment up front is very good & no spacer is needed but the spokes are very close to the Brembo caliper & w/your Endless calipers there maybe an issue or maybe it offers better clearance???
Heres a thread w/a few guys running this same wheel
https://www.evolutionm.net/forums/sa...34-offset.html
Old May 1, 2017, 12:43 AM
  #3396
Thanks! Will check the thread out as well.
Old May 1, 2017, 01:21 AM
  #3397
I had a new idea. If I run 18" x 9.5" +22 TE37s with 265/35/R18 tires, I'm sure I'll need rolling/pulling of the fenders. But, do I still need to do the fender work if I had Voltex overfenders?
Though about it after I saw this photo:
http://image.superstreetonline.com/f...ion-1-aero-kit
Old May 1, 2017, 06:02 AM
  #3398
That TE37 +22 has been done many times on stock body EvOs, but youre right, it does require all the mods to the rear fender (roll, pull, bumper bolt) Please note: Most installations are not done right. Most do not do the rear fender pull or the bumper bolt & run too much rear camber & are rubbing)
The over-fenders require a full cutting of the rear fender. Once this cutting is done, there is no going back
Old May 9, 2017, 02:56 AM
  #3399
Jp7
Jp7's Avatar
does anyone have pictures of 235/45 17 with 17x9" wheels?
Old May 9, 2017, 06:00 AM
  #3400
^^^Been done many times. The 235 is the narrowest tire recommended for a 9" wheel
Heres a thread w/some pics
https://www.evolutionm.net/forums/sa...-w-advans.html
Old May 25, 2017, 12:55 PM
  #3401
ineedboostman's Avatar
245/40R18 on 18x9.5 +22
I've read so many different threads and at this point I'm just out of time. The tire I'm looking at is 245/40R18 Federal 595 RS-RR on 18x9.5+22. The tire height per their website state 25.7 inches. I currently have 255/35R18 on with no problem but was looking for a little extra sidewall to cope with the power. The car is around 700hp. Will this be too much stretch? Should I stick with the 35's? The Hankook Ventus I have on now are like a slip n slide and it quite dangerous. I'm also concerned about loosing some footprint stepping down to the 245's.
Old May 25, 2017, 02:26 PM
  #3402
The min size allowable on a 9.5" wheel is a 245. I think you are OK w/that size. If I got the treadwear rating correct on the Ventus it shows a 320. You might be better off running a tire w/more grip (i.e 200 treadwear tire)
Note: Federal tires run about a size wide so a 245 Federal 595 is more like a 255. I run their 595 EvO 265 /40 tire & its the same as my old Nitto NT05 275's
The 40 series tire is OK as it is relatively close to stock (-1.52% taller)
Hope youre properly fitted for those +22 offset wheels as that is a very aggressive wheel for the stock EvO rear
Old May 25, 2017, 03:28 PM
  #3403
Federal 595rs rr p245/40r-18
I fit the wheels best I could by rolling the fenders and adding camber. I did not get it aligned yet. I'll have to pull the strut and do it correctly in the near future. Really my biggest concern is running the 35 for clearance of the strut / fenders vs running the 40 for more tire. Is it necessary to have more sidewall the more power you start making to help make it safer and soften the blow to the drivetrain ? I don't want to order the Federal 245/40 and find out things start rubbing all over the place because with the Ventus tires nothing rubs.
Old May 25, 2017, 03:38 PM
  #3404
Its going to be on the 18's that I was questioning the 40 because I know the 35 should fit. When it says its 25.7" on Federals website with the 18's that still only going to be 1.52% taller?
Old May 25, 2017, 03:57 PM
  #3405
Well, as noted, if you go w/the Fed 245/40 it will the same as running a 255/40.
I wouldnt be overly concerned about whether a 40 vs 35 series tire is better for a high HP car
The 40 series will certainly offer more road protection & a slightly softer ride (same tire compared to same tire)
Youre currently on a 255/35 so running the Fed 245/40 is still close to the stock circum
Due to your high HP, I think a good summer only tire w/a softer compound will be better suited for your car (i.e. Nitto NT05's or the Federals)
If you have only been rolled, you really need a slight rear fender pull & w/the 40 series tire you may find youre hitting the rear bumper bolt (should be moved rearward)
Quick Reply: Tire / Wheel Fitment Questions
