Tire / Wheel Fitment Questions
Old Feb 26, 2018, 06:52 AM
  #3676
kyoo's Avatar
if you're going low to mid 30's just FYI it will be easier to clear the front suspension on the inside with the "low camber" setting on the eccentric bolt, with still plenty of fender clearance with ~-3 degrees of camber
Old Mar 1, 2018, 07:16 AM
  #3677
WretchesNKingz's Avatar
Will these fit my evo 8
I'm
Trying to figure out if these will fit and clear brembos....have to drive to get them don't want to waste my time if they don't please help thanks
Old Mar 1, 2018, 07:17 AM
  #3678
kyoo's Avatar
no
Old Mar 1, 2018, 07:37 AM
  #3679
Received 1,384 Likes on 1,317 Posts
Originally Posted by WretchesNKingz
I'm
2 major issues. The +45 offset & the bolt pattern. Our bolt pattern is 5 x 114.3
If you have other questions, let me know
Old Mar 1, 2018, 08:03 AM
  #3680
Old Mar 1, 2018, 08:41 AM
  #3681
One spec I missed was the 7" wide wheel. Unless this is to be used for a snow tire spec, this wheel is really out of sorts for our Evo
You would be better off w/the stock wheel at 17x8 +38 vs this 17x7 +45 (The wheel does appear to have a dual bolt pattern at both the 100 & 114.3)
Old Mar 1, 2018, 09:13 AM
  #3682
I have the stock bbs but just want a new setup that's not 2 expensive I can get these rims for a really good price. The bbs I have are all tore up haha
Old Mar 1, 2018, 09:36 AM
  #3683
Yeah, we need to find you another set of stockers. Maybe change over to the EvO9 wheel? Or look for a nice set of Rotas / 5Zigen. The size i recommend would be: 17x9 +34 to +38
Let me know if you find something & will be happy to check the fit for ya
Old Mar 1, 2018, 12:01 PM
  #3684
What would you recommend for 18" without rolling the fenders? It seems like there's more 18" for sale
Old Mar 1, 2018, 12:05 PM
  #3685
Theres no exact answer but generally speaking, I feel the range falls into this:
17x8 to 17x9 w/an offset range of +34 to +38 (tire size 255/40)
18x8 to 18x9 w/an offset range of +34 to +38 (tire size 255/35)
Old Mar 2, 2018, 07:32 AM
  #3686
Astro_Train's Avatar
Originally Posted by kyoo
here's my rear fitment pic with my ce28n 18x9.5 +34, 265/35-18 RT615k+!
can you post a pic of whole car? Odd those 265s look stretched on a 9.5 inch rim.
Old Mar 2, 2018, 07:55 AM
  #3687
kyoo's Avatar
planning to drive the car for the first time in 3 months on sunday - will post some pics of it in the wild then!
Old Mar 3, 2018, 05:17 PM
  #3688
17x8 front and 17x9 staggered
What you guys think I want to run this setup I've heard that it's bad but also that it not depending if you have the right rolling radius. If you do the calculation. And get the right size tires. Does not strain the gearbox. 225/40/17 front 255/35/17 rear this is the thread I used
http://www.lancerregister.com/showthread.php?t=480196
Old Mar 4, 2018, 05:14 AM
  #3689
The general opinion from almost all on this forum is to keep everything square. Dont mess w/diff size tires.
The most the guys do here is run the same wheel, same tire but a diff offset front & rear (see Enkies RPF1's)
Keep it square
Old Mar 5, 2018, 06:51 AM
  #3690
kyoo's Avatar
also, that sounds awfully understeer-y
MinusPrevious (Mar 5, 2018)
Quick Reply: Tire / Wheel Fitment Questions
