Reverse staggered wheel width question
Old Jan 31, 2011 | 10:01 AM
Boltz.'s Avatar
FCOTM Winner
Hi, {CLIFF NOTES IN BOLD}
I am selling my 18's and moving to 17's in hopes that I will get to enjoy more track time since my wear items would be cheaper. I have been searching around quite a bit for a good track wheel (width/offset) at a reasonable price and have searched this topic before creating my own thread.
Goals:
Wide'ish tire. I want to try the RS-3 255/40/17, but it is a little narrow. Other options are the Z1 in 265/40/17 and the Conti DW in 275/40/17... I don't think I really need a 275, but who knows.
Not require spacers
Cheap
I was looking at the usual suspects like the NT03 (hate the 17" version), RPF1 ($250/wheel plus spacers), Rota grid (17x9 +25 and 17x9.5 +30) and them I came along the MB battles...
The MB battles come in 17x9.5 +15 and 17x9 +30....
I went back and forth between the two and was thinking the +15 won't work in the back without a skinny tire and the +30 just won't look that cool....
So after more searching and zone'ing out about things to buy for my car I thought about a reverse stagger. 17x9.5 +15 in the front and 17x9 +30 rear, both obviously would be on the same tires.
I have read that you can possibly create a different circumference by stretching the wheel more but I don't think that will be an issue in this case.
So I am left curious; will the staggered widetrack in front cause issues with the AWD system other than the obvious? How will this effect the vehicle at the track? I am running a square spring setup (572lb Ohlins)
Any input is great.... I know Evolutionary has done this in autocross, but that is a track car and mine is a street/strip/track car.
Thanks guys,
Justin
Old Feb 2, 2011 | 11:31 AM
Girodisc Martin's Avatar
It could change but I bet they would be super close not enough to cause you a problem. You could probably even them out with tire pressure just run a few more lbs in the rear tires. If I were you I would just run the same size wheel and get spacers for the front. I did this on my WRX wagon and it made it much more tail happy. I loved it. It pivoted much better and I was able to do more power over maneuvers instead of trying to scrub off understeer. Now I am not sure what this would do to an EVO but I assume it would be the same.
Old Feb 3, 2011 | 08:17 PM
MJ23FE's Avatar
Here's an article I came across a little while back about reverse staggering.
http://www.therealjdm.com/archives/TheRealJDM01.pdf
I'm sure if you're looking to gain every last piece of grip on the race track, that this setup could be/is beneficial, but on the street, it doesn't seem necessary at all.
-Jalal
-Jalal
Old Feb 5, 2011 | 08:22 AM
Boltz.'s Avatar
FCOTM Winner
Thanks for the article Jalal!
Deanjobs666
Mar 12, 2013 01:16 AM
ChadS
Jun 18, 2011 07:44 PM
L888Apex
For Sale - Wheels / Tires
15
Feb 24, 2010 08:18 AM
andres_d85
13
Apr 19, 2009 08:00 AM
blueprint
34
Mar 30, 2009 12:28 PM
