Cycling ABS Module During Brake Bleeding
Old Mar 5, 2011 | 04:25 PM
blknblubkrdude's Avatar
I recently reinstalled all the brake calipers into my EVO after getting them powdercoated.
I used my Motive Power Bleeder and got all the components full, but the pedal was still mushy.
I had my trusty assistant (GF) run the brake pedal while I bled. I noticed a lot more air came out this way.
I did have the engine running (as the Service Manual reccomends) both times, and went through 3 quarts of fluid.
The pedal is better, but not up to spec. I believe air is trapped in the ABS module
Does anyone know of a way to cycle the brake system without the use of a Mitsu scan-tool, or evoscan?
Thanks!
Old Mar 6, 2011 | 09:30 AM
JDMS60R's Avatar
Thats weird I just changed out my abs module, and just bleed it normal. No key on or cycling or scan tool, everything is rock solid. Maybe I just got lucky, I know that doesn't help you any, but its possible to do.
Old Mar 6, 2011 | 10:49 AM
I know it is possible, as when I worked for Cadillac/GM I did it several times. There was only 1 occasion I needed to use the Tech 2 to run the abs pump.
I guess I'll just go ahead and buy the Tactrix, that way I can get rid of my EGR / Rear O2.
Thanks!
Old Mar 6, 2011 | 02:15 PM
grahamab's Avatar
you might want to look into whether or not you can cycle the ABS using Evoscan. I wasn't sure that it worked, but I might be wrong.
Old Mar 6, 2011 | 02:29 PM
When searching, I only found one thread that related to mine:
https://www.evolutionm.net/forums/ev...s-evoscan.html
It seems like evoscan will not do that function.
Old Mar 15, 2011 | 04:10 PM
Well I bled and bled some more. The brakes movement is still way out of spec (.8 inches) I am driving it now for the first time in hopes to get the bubbles freed up.
Old Mar 20, 2011 | 05:17 PM
Cycled almost 2 gallons of fluid through them after putting about 100 miles on the system trying to break some bubbles loose.
Any help?
Thanks
Old Mar 20, 2011 | 08:31 PM
rawkus's Avatar
I have the tool to cycle ABS while bleeding brakes and... well... it doesn't really help as the fluid stops flowing when the ABS is cycled. I too use the Motive Bleeder and have also bled the old fashion way. One thing I have done is use both the Motive and old fashion way at the same time and that has worked. Make sure you don't have crazy pad taper or a stuck piston as that can affect the pedal feel. Good luck!
Dan
Old Mar 22, 2011 | 03:15 PM
My calipers have all new seals/boots, and the pads are new EBC reds.
I spent another couple hours this morning bleeding, and went through about 3 quarts more of fluid.
I finally got the pedal within spec (<.8" freeplay")
I was so stoked I could not believe it.
I put all the wheels back on, pull the car out of the garage, and about two pedal strokes later I get some mush. WTF?
It is definitely out of spec now, but it's liveable.
Some other day, lol.
Old Mar 23, 2011 | 10:41 AM
andrewzaragoza's Avatar
if its getting mushy again you may want to check all your brake lines for leaks.
Old Mar 23, 2011 | 10:43 AM
milford's Avatar
are you bleeding both valves on each caliper?
Old Mar 23, 2011 | 12:43 PM
That's the first thing I checked. It's good to go.
That's what I thought, but the way it happened wasn't as if there were a leak.
10-4! I have worked on and bled a variety of brake systems as a GM/Cadillac specific tech, and never had any problems bleeding like this.
There has to be air trapped somewhere, because I bled for hours until not a single molecule of air would come out.
I think I may invest in a reverse bleeding pump, and give that a shot.
Thanks!
Old Mar 24, 2011 | 06:48 PM
rawkus's Avatar
The other little thing I did that helped, was bleed the outside of the caliper, then inside and then do the outside again and every once in a while we saw a little bubble doing that.
Dan
Old Mar 24, 2011 | 10:57 PM
barneyb's Avatar
I'd like to know how they wet the brake systems these cars with ABS at the factory. I had another car that I bled and bled and got it pretty good but then when I opened a line at the proportioning valve, I found the valve dry. There has got to be something we are missing.
Old Mar 29, 2011 | 06:07 PM
I agree. I put the EVO back on jackstands and bled the s'not out of them again just using the Motive bleeder.
I got a decent amount of air out of them, but nothing significant.
The pedal play is still out of spec @ 1.3" of play.
I have no idea where the air is trapped.
I really wish I had a way to cycle the abs when the system is pressurized during bleeding.
