Cycling ABS Module During Brake Bleeding
Old Aug 24, 2012 | 05:28 AM
  #46
sr20det91's Avatar
How do you bleed the MC without pulling it off and bench bleeding? When I talked to the guys at motive products they said that may be a possibilty because sometimes air gets trapped in the tip of the MC and its next to impossible to get out without bench bleeding.
Old Aug 24, 2012 | 10:14 AM
  #47
griceiv's Avatar
just like you bleed the rest of it except you disconnect the lines from the MC.
Old Aug 24, 2012 | 10:34 AM
  #48
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Is that also in the FSM?
Old Aug 24, 2012 | 12:12 PM
  #49
griceiv's Avatar
yep.
Old Aug 26, 2012 | 05:23 AM
  #50
sr20det91's Avatar
Thumbs up
Sounds good guys and thanks again for the pointers. I'm on vacation for the next week, so as soon as I get back I'll give it another try and report back.
Old Jan 25, 2013 | 06:06 AM
  #51
McLaren F1 2003's Avatar
Originally Posted by blknblubkrdude
Air in the clutch system should not affect brakes. They share the same reservoir only.
A defect in the pad or rotor can cause squishy brakes, as the pistons can be pushed back into the calipers, requiring more pedal travel to make up theextra clearance.
Most likely the air is in the ABS, like mine was. You need a constant pressure of fluid (Motive bleeder) and open every fitting on the unit, and let it pour!
Dumb question, but when you say every fitting, do you really mean all 6? or just the 4 that lead to each corner of the car?
Old May 25, 2014 | 05:41 PM
  #52
blockade35's Avatar
I was having the same issue (solid pedal with car off, felt squishy for first couple inches with car on) and spent literally all day pressure bleeding, 2 man bleeding, and gravity bleeding to no avail. Come to find out my titanium shims up front had gotten warped, so the first inch or so of pedal travel was just bending the shims back to flat. Not sure if this is the same issue anyone else had but figured I'd post up my solution here anyways to see if it could help someone in the future.
Old May 26, 2014 | 09:13 AM
  #53
babyd's Avatar
just read through this thread, the best and easiest way ive found to do an ABS is to throw the car up in the air (or on jackstands or whatever) and then put it in gear, get it up to 25/30 mph and do a couple hard stops. the ABS unit freaks and runs the pump like crazy and actuates all the valves trying to figure out how to slow the car down with it in the air like that, it pushes alot of fluid through the abs block and frees any stuck bubbles on any of the valves.
do it all the time at work on BMWs and on my own evo as well. any time the braking system is open above the abs block you should do a complete ABS bleed or the pedal will never feel right, the trouble is in order to do a ABS bleed on one of those cars you have to hook up to the ISID computer and do a lengthy and incredibly painful bleeding procedure, but i figured out one day that just running the car in the air on the lift and jacking the brakes a bunch of times works just as good as the computer-controlled bleed procedure and saves about an hour. works on my evo the same way.
Old Aug 29, 2014 | 11:23 AM
  #54
2gsxtasy's Avatar
Originally Posted by rawkus
The other little thing I did that helped, was bleed the outside of the caliper, then inside and then do the outside again and every once in a while we saw a little bubble doing that.
Dan
This. I know this is an old thread but we could have bled my front driver caliper outside for a year and I still would have had air. We switched to inside bleeder for about 3-4 cycles until no air then switched back to outside and after 1-2 all the air was out. I'm amazed this hasnt been posted more. We actually went around and then did ALL of the calipers that way in the old fashioned order (furthest to closest of reservoir) but ran out of brake fluid so this morning we are in the process of going back through the "Evo" bleed way (rear pass outside/rear pass inside, front driver outside/front driver inside, rear driver outside/rear driver inside, front pass outside/front pass inside) to ensure by going out of order last night we didn't introduce anything into the system.
Hope this helps someone in the future, long story short to confirm - if you're having air issues try this.
Old Jun 23, 2016 | 06:46 AM
  #55
ace33joe's Avatar
Sorry for bringing back an old thread, but Evoscan abs actuation is still not possible? I tried with my v2.9 and 1.3U Tactrix cable tonight, but didn't work.
95b18ccivic
For Sale - Part Outs
15
Apr 21, 2017 07:40 PM
GrannyShifting
Mar 21, 2017 05:25 PM
95b18ccivic
15
Jan 3, 2017 03:53 PM
05OBP
Dec 22, 2016 12:29 PM
xceler8rob
Feb 29, 2016 09:58 AM
