Sensible summer tires
Old Jun 20, 2016 | 11:28 AM
thatevo_sj's Avatar
Does anyone with full negative camber have experience with sensible summer tires?
I've been running RE-11A/Z2* for DD. Fun times, but I would like to reduce my cost/mile a bit.
Looking for reasonable cost, decent grip, medium treadwear, good wet handling. No need to handle freezing temps - so all seasons are not on my list.
The complicating factor is camber : I had some 340 treadwear Conti DW's that I really liked for price/performance/treadwear, but my -2/-1.5 camber killed them in 15k miles (inside corded with outside at 1/2 tread...).
Old Jun 20, 2016 | 12:26 PM
heel2toe's Avatar
That is not a very aggressive alignment. What is your toe? Im guessing you have toe issues or else you drive like a grandma but even then 15k on a tire like that and that alignment doesnt add up.
Old Jun 20, 2016 | 12:50 PM
LetsGetThisDone's Avatar
Yea, something else is up, I got 15k and 10 autocrosses out of the Dunlop Z2* I had on my car. What's the toe in on your alignment? At zero toe in that alignment should be fine. You could maybe run a little less camber in the rear 1-1.2. But it shouldn't really matter.
Old Jun 20, 2016 | 12:59 PM
Aby@MIL.SPEC's Avatar
yeah, check your toe settings.
im @ similar settings, minimal toe out.
i have ~25/30 on my michellins & got simlar mileage out of my previous conti dw tires.
Old Jun 23, 2016 | 11:28 AM
thatevo_sj's Avatar
Thanks for the responses guys.
I get usually get 10-15k out of my 180-200 treadwear tires, (depending on how naughty or nice I am that year) - so the excess wear on the Conti DW's surprised me.
I was running with a little bit of toe in front and rear at the time - I was trying to save $$ and use a conservative alignment... I'll have to dig up the paper and see what the #'s were. I usually have 0 front and little toe out rear. Funny if my attempt at a conservative alignment killed them...
Old Jun 23, 2016 | 11:53 AM
Toe in usually wears the outside edge a bit faster. So with how you wore the tires, I would say run less camber, or drive the car harder to use up more outside tread lol
Old Jun 23, 2016 | 01:21 PM
NeedNoRoad's Avatar
yeah, just run less camber
Old Jun 23, 2016 | 03:52 PM
Neal@tirerack's Avatar
May want to check out the BFG GForce Sport C2 or B-Stone RE760 as a longer life sport tire. Thats two classes below the extreme perf RE-11's. One step below would be B-Stone's S04 or Michelin Super Sport.
Old Jun 28, 2016 | 04:04 PM
03whitegsr's Avatar
15k miles on a set of tires is bad?
Must be my driving but I'm feeling good if I get 12k before there is no tread left, pretty much on any tread life tire (harder tires slide more???). I don't usually have issues with camber wear though and I'm running -2.5* currently in the front with 1/32" toe out. Every corner I get the chance to rip around, I usually do.
Jrod@Buschur
Evo 'For Sale' Engine Internals and Drivetrain
41
Sep 13, 2012 12:44 PM
jag0
55
Aug 30, 2010 01:23 PM
damstr
Jan 25, 2009 07:28 PM
