steering wheel shakes over bumps
Old Jun 16, 2011 | 10:04 AM
tuddy's Avatar
Ive searched a ton on this, but if someone can out search me chime in.
My steering wheel loses control over small bumps, and it is getting worse.
It feels as if its mainly from the passenger side.
Ive jacked up the front end, held my hands at 3 and 9, tried to rock the wheels, nothing moves, Ive put a pry bar on all the control arm bushings, end links and tie rod bushings to see if anything is really noticeably failing and I've come up with nothing.
Any suggestions would be much appreciated.
Old Jun 16, 2011 | 10:21 AM
dastallion951's Avatar
check your upper strut mounts for cracking and movement when you turn the steering wheel, also shake your tire at 12 and 6 oclock position that checks for bad ball joints and also a loose hub/bearing... good luck
Old Jun 16, 2011 | 10:23 AM
tuddy's Avatar
i tried the 12 6 shimmy, but ill check the strut mounts now - thanks!
Old May 21, 2012 | 03:49 PM
Limpiabota's Avatar
results?
Old May 21, 2012 | 03:51 PM
Limpiabota's Avatar
results?
Old May 23, 2012 | 11:27 PM
BoostAddict420's Avatar
Same issue..ended up being strut mounts and a bad axle. Good luck and check our axle boots as well
J!n K@z@mA
19
Mar 8, 2016 11:34 AM
purpledranktown
Jan 6, 2016 07:19 PM
slowonder
Mar 6, 2012 07:06 PM
Trever007
14
Jul 28, 2009 05:33 PM
x838nwy
14
Jul 9, 2006 01:23 AM
