Exhaust rubbing on front braces?
Old Nov 11, 2011 | 08:33 AM
Evo11V's Avatar
Veteran: Army
Recently for what ever reason the exhaust is rubbing on the stock braces underneath. Its an AMS 3" exhaust, what do you guys recommend? I used to rub minimally from time to time but now its just too much.
I saw the GSPEC Front 4 point ladder brace but was woudnering if that is the best option since I need to get something that will clear the exhaust and stop the annoying noise at certain RPM ranges or driving around the parking lot.
Thanks all happy Veterans Day!
Brett
Old Nov 11, 2011 | 08:57 AM
Smike's Avatar
You can shim the brace down a little bit or hammer the piping some to get it out of the way.
I used shims on my car.
Old Nov 11, 2011 | 09:00 AM
Evo11V's Avatar
Veteran: Army
Yeah Just trying to see if they have something out there that will give me more room. The front one its basically sitting on and I have 2 spacers in there, the one behind that has enough room.
Old Nov 11, 2011 | 10:09 AM
Boostd4's Avatar
I stacked a few washers in there...had to experiment a little to get the right set. Just make sure you're not running out of thread on the bolts as you're adding washers.
Old Nov 11, 2011 | 10:12 AM
kpr's Avatar
kpr
Take a look at the RMR ( Rhys Millen Racing ) front brace. Its the only one made to clear a 3' exhaust.
Old Nov 11, 2011 | 11:10 AM
LCS's Avatar
LCS
I think it´s odd. Did you check the exhaust mounts? Looks like something is sagging.
Old Nov 11, 2011 | 11:17 AM
llDemonll's Avatar
I have a full 3-inch and while it's a very close fit, I don't rub at all. I have a Megan downpipe since I know they're all a tad different probably
Old Nov 12, 2011 | 05:05 AM
GG06MR's Avatar
I had the same issue. Get longer bolts, and make it 3 sets of washers, and you'll be set.....like I had to do.
Old Nov 12, 2011 | 07:23 AM
deeman101's Avatar
Shimming is probably the easiest/quickest/cheapest way. And not much wrong with it.
Otherwise you could use a carbing 6 point bar which apparently has a lot of clearance. Or a works croxx plate. I use the works with a megan 3inch. Its got room...but not a whole ton of it. My dp never hits or vibrates against it or anything though.
Old Nov 12, 2011 | 10:41 AM
killerpenguin21's Avatar
i have a buschur spacer kit sitting in my room that i wound up not needing. if you want it you can have it cheap, it should let any exhaust fit without hitting.
Old Nov 14, 2011 | 02:48 PM
Evo11V's Avatar
Veteran: Army
I'll have to take another look, see what I can come up with but its basically resting on the brace. It used to vibrate once in a while and now it finally got worse. Thanks for all the replies.
Old Nov 15, 2011 | 09:44 AM
boomn29's Avatar
Buscher sells big spacers and new bolts with their exhaust. That's what I have, and no rubbing!
Old Nov 15, 2011 | 11:12 AM
HMatt's Avatar
Shim it or buy the carbing 6-point.
My buddy's evo just needed a touch of clearance, so we were able to get away with a stack of 3 washers just on the middle bolt on the front bar and bend the bar a little.
Old Nov 15, 2011 | 12:52 PM
Dallas J's Avatar
Veteran: Army
I think I used some old head bolt washers with a stack of 2 or so on each side. The on the one that was closest I cut a rubber hose in half (like a 1/2" hose), and zip tied it so it would rub on that instead of the metal bar. After 2 years it hasn't melted so Ill call it good.
Old Nov 15, 2011 | 04:45 PM
eagles710's Avatar
i have the same problem with my dc downpipe. I only hear the rubbing when it rains and is very annoying. I was thinking about spacing the brace out so it doesnt touch but i solved the problem by just not driving in the rain anymore lol
