Rear diff options for the street
Old Jul 28, 2011 | 07:20 AM
FJF's Avatar
FJF
A big note of thanks to everyone who took the time to post.
None of the usual suspects want to chime in? I'm trying to make a decision.
Old Jul 28, 2011 | 08:54 AM
killerpenguin21's Avatar
Originally Posted by Brainiac
There's a youtube clip of someone demonstrating the 12 plate in an autocross course..I think if you search "TRE 12 plate" it's the first clip. Take a look..he goes through a normal and aggressive turn on the course.
it was evojoe. vid pops up in google if you search evo joe racing.
i wonder if he drives his car on the street much?
Old Jul 28, 2011 | 09:09 AM
Montu's Avatar
the only reason I said you wouldn't make use of the 12 plate on the street is because you said 99.99 percent is street use..so whats the point? on the street you will probably be trying to avoid the rear end coming out with the 12 plate...seems to me the 8 plate will be closer to stock for dd duty while still reducing under steer
I personally have the 12 plate but i try to go to the track as much as i can.
Old Jul 28, 2011 | 09:29 AM
FJF's Avatar
FJF
Though I drive the car almost daily, it's not really a daily driver. I tried explaining how the car is used in the first post, but there's only so much that can be said without breaking the rules. This being said, I see your point. I don't want to have to catch the rear, as I'm flying into a blind corner not knowing what lies after the (assumed) apex. Given the weather and the road conditions where I live, that effect can be compounded.
I've always leaned toward the STU-legal diff, as it's a milder approach and I'm a mild driver. As anyone, I'd hate to go through the process without feeling like all the options weren't explored. Thank you for the comments.
Old Jul 28, 2011 | 09:50 AM
evremonde's Avatar
I don't think that the diff is a factor in this situation. If the 12 plate functions as a 1.5way diff, then the car should be more stable under braking or trailing throttle situations.
Old Jul 28, 2011 | 10:03 AM
Montu's Avatar
bottom line is the 12 plate is great and you can over steer on command..the car will act different on the street while breaking some laws
the 8 plate should be more mild and closer to stock...less surprises but I'm pretty sure if you went with the 12 plate you wouldn't wreck or anything.
personally seeing how my car is on the street with the 12 plate...although fun I don't think its needed for fun on the street.
if i didn't track my car I would have gone with the free 8 plate
Old Jul 28, 2011 | 10:09 AM
FJF's Avatar
FJF
Fair enough. I try to brake in a straight line, sometimes trailing a little just past turn-in, gradually shifting into the throttle before the apex, (hopefully) nailing the pedal on my way out. A lot of the time, real life doesn't make it happen and the maneuver has to be aborted somewhere in the middle. Like I said, I'm not exactly Colin McRae behind the wheel. Given the driving scenario I described, do you still feel the car would be more stable with 12-plate?
^^^ That's pretty much what it comes down to for me. What do you guys think?
Old Jul 28, 2011 | 10:21 AM
andrewzaragoza's Avatar
I suggest going for the free 8-plate first. see how it goes then if you want a more aggresive rear diff then thats the time do the 12-plate.
Old Jul 28, 2011 | 10:24 AM
FJF's Avatar
FJF
Like I said earlier in the thread, the diff will be professionally built and installed. The cost is almost the same either way. I'd only like to do this once.
Old Jul 28, 2011 | 10:25 AM
Boltz.'s Avatar
FCOTM Winner
Originally Posted by Piro Fyre
As for getting in trouble in the street, no. It's not illegal to have an LSD and have it working to drive your car in the streets.
FJF is gonna get pulled over for having too many plates in his rear diff. Sending you to smog for a diff dis-assembly.
Old Jul 28, 2011 | 10:34 AM
Dallas J's Avatar
Veteran: Army
Because you have soft springs and big bars you'll be transferring a lot of weight from the inside tires to the outside. With that much unloading you'll probably want as much lockup as you can get in the rear to keep the inside from spinning. This will also help reduce your understeer as well. Its not in the sense that you'll have less rotation but less overall demand on the front in circumstances where the inside rear is spinning.
Its a little hard to explain in text, but with the inside rear spinning you have an increased rear drive shaft speed. The center diff is at this point trying to lock things up and keep it 50/50 so more load is transfered to the front (the diff is tight, front drive shaft speed is trying to match rear). That ends up over loading the front tires causing understeer. Its very gradual on an ACD equiped car but can be felt real strong on a VC car (like my Talon before the rear Max-lock).
With that said, in you're situation I would get the maxlock and use OEM diaqueen fluid. The STU guys make the 8 plate work with heavy springs and light bars reducing weight transfer so each tire has more load to do more work, and the inside rear is less prone to letting loose.
Old Jul 28, 2011 | 10:52 AM
evremonde's Avatar
^ thats a good description. A better locking rear diff increases overall grip, rather than just creating a power-on oversteer condition.
big rear swaybars do the opposite, you get oversteer mainly because you reduce rear traction (i.e tripoding)
Old Jul 28, 2011 | 01:23 PM
FJF's Avatar
FJF
Interesting points all around. Thanks for posting.
Old Nov 11, 2011 | 05:59 AM
bhmax's Avatar
Did you make a decision on this? I also see myself doing this and am looking for more input from someone like you and what you described you're hoping for out of the mod.
Old Nov 11, 2011 | 06:11 AM
Smike's Avatar
Yeah, any direction you have gone with Felix?
Looking at where I want to go with the next racecar. One of which is an 03/04 8 with very basic mods for TTB. The rear diff mod (or free mod) is high on to-do's if I get one.
