Rear diff options for the street
The diff truly enforces the fact that an Evo is a slow in - fast out car. Steady state understeer is almost inevitable unless you decrease rear grip (to much bar, extra air pressure (my preference), etc), or get more traction in the front running an offset tire size. So to counter this on an Evo with whats usually an abundance of power, most things are driven in the transitional phases while keep the steady state to straight lines or large arcs.
Always braking in a straight line, rarely trail braking, and being back on throttle all the way through the turn... Thats how you'll make the evo feel like magic.
With this driving style, the Rear diff is a huge gain. From my post above of how I feel the rear diff effects front grip, its clear to me that to accelerate through the corner you need the rear to be doing its full share of the work.
Keep us posted
Could start putting calendars of cars with those overly gussied up gals everywhere...then slowly transition to just awesome car calendars. Subtle hints to love cars.
You might want to consider the extra noises that will come from a 12plate upgrade. It can be trivial or annoying depending on the person. And really I don't think anyone has ever posted their experience of the diff in wet / snow conditions. Would be good to know.
Yeah but the 8 plate makes noise too. It is starting to get a little annoying but it has improved my cars handling for autox. I am debating a 12 plate upgrade as we speak. I have driven my car in rain pretty aggressive and with RS3's and found the car to still have tons of grip so I can only assume that unless really pushing your car it won't be a death trap or unsafe for somebody with common sense.
In all fairness, I can get the car to oversteer pretty easily on the throttle in the rain, and other likely can, as well. I think we're mostly concerned with the difference in the car's response with a locking diff.
I have the 12-plate.. I went for a spirited drive in the rain last night, i feel it had the same oversteer as before... I wasn't on a track or closed road so i wasn't pushing it, but its not something to fear.. I've had my diff for 3 weeks now and am totally used to it. U can anticipate the oversteer in the dry, and if u enter a corner too hot u know for a fact that u can WOT and it will FOR SURE oversteer u out of the corner.. There's no wondering "hmm will it under or over". Since the 12 plate upgrade i haven't experienced understeer yet, been to Streets Of Willow twice, and lots of mountain driving. Also being used to the diff when daily driving u can make the diff not as clunky when going thru a parking lot, or making that left turn at a light. You get used to it and i cant stress enough how amazing the 12 plate is. U dont want to settle with anything lower
Not as easily. I find I have to use a lot less throttle to get my car to oversteer in the rain whereas before it required full throttle or for me to carry a lot of speed into a turn. The rain really isn't what we should be focusing on here though as it is dry grip that causes understeer. Coming from somebody who has done the stock diff mod I say I have already outgrown it and currently looking into the 12 plate upgrade.
^ On the 6 plate how was the lock up on the diff. Especially between grip and oversteer? Gradual, snappy, easily controllable with the throttle, on/off switch, etc. Does it just put the power down and go or give you too much oversteer drama going around a corner on the track (assuming you're against the clock). Will it step out only when you want it to, or do you have to chase the rear sometimes.
l8r)
