Any issues with this setup?
I want to run some Varrstoen ES 2.2.1's and the specs are gonna be
18x9.5 5x114.3 +22 with 265 35 18 tires
What i need to know is will the tires fit good and will i have to roll my fenders My car's not slammed but I do have coilover's.
I search forms about this I think i found the answer but I just wan't to be sure.
A 285 hoosier needs about 38-40mm offset to fit perfectly and they run big, more like 295s. So 30mm difference in width between a set of hoosiers and those 265s would give 15mm more rubber on each side. As far as the outer tire edge, you'd be within a couple mm of where the hoosier sits so Id assume you could fit it with just a roll.
This is all speculation of course and also limits and future growth if you wanted to go bigger without buying a new wheel.
TwStDeVo
Mar 10, 2009 03:37 PM
nikkadanny
Oct 2, 2007 08:25 PM
