MR Bilsteins/Swift Spec-R: Most aggressive 18" wheel width and offset?
my car is currently running mr bilsteins and swift spec r springs. i want to run an aggressive offset and width 18inch wheel for my set up, especially considering i have hrs wide fenders upfront and rolled/pulled rear fenders. right now im running 18x9.5 volk time attacks +28 with a 15mm spacer upfront (to fit nicely with the fenders). some wheels im looking at are 18x10 +18 and 18x10+35, but i want to know what all my options are including in the 9.5 width. btw, tires are reo1-r's in 255/35/18. appreciate the help!
18x10 +18 and 18x10+35 - is very aggresive in the front but you should clear your brakes fine - i would hang onto those tires because u will probably have to stretch them on to fit these wheels on- (does promote wheel spin tho) or you could run alot of camber but do to your stock style setup you cant adjust camber much- so you might have to buy camber plates.
i would contact togue factory (spelling?) they seem to be good with running aggresive setups
well im not worried about the front at all since i have the hrs fenders , well maybe a little due to the clearance for the shock compared to a coilover set up. the rear is my main concern for clearance.
here is an example in the rear
18x10 + 15
245/35/18
https://www.evolutionm.net/forums/ev...e-content.html
18x10 + 15
245/35/18
MRak
Nov 15, 2013 09:22 AM
Steiner
Mar 1, 2010 12:47 AM
