Slide on wheel spacers, Where do I get them?
Old Aug 14, 2011 | 07:28 PM
Dallas J's Avatar
Veteran: Army
All I can find is spacers in the bolt on variety and Im not of fan of them. I want a non-universal (those crappy terribly fitting generic things) ~25mm spacer.
I know they're out there, but for the life of me I cant find who actually sells them.
Old Aug 15, 2011 | 01:34 PM
XcreatonX's Avatar
I got a 18mm set from JMfab. I haven't had a chance to use them but look like they fit well.
Old Aug 15, 2011 | 01:50 PM
Dallas J's Avatar
Veteran: Army
Those are pretty close to what Im looking for but they only come in hubcentric sizes not suitable for the stock wheels. Guess I might just have to do some research on bolt on spacers as much as I dont like them.
Old Aug 16, 2011 | 05:52 AM
gsrboi80's Avatar
I used Project Kics from Phil at 201 Motorsports when I had Volks they worked awesome
Old Aug 16, 2011 | 05:56 AM
marcusE's Avatar
I've got 18x8.5 RPF1's with a +30 offset.. I want to look stanced out as much as possible without stretching tires like a jack*** I have Coilovers already. Should I think about maybe some spacers as well? Also at what point do I need to extend my studs?
Old Aug 16, 2011 | 06:03 AM
RJones's Avatar
I just bought bolt on spacers and pressed the studs out of them...
Old Aug 16, 2011 | 07:32 AM
Dallas J's Avatar
Veteran: Army
Do you know what the weight of those are? Probably insignificant in the grand scheme of things. Im now thinking of just CNCing out a set of my own webbed design if I can justify the weight difference.
Old Aug 16, 2011 | 07:34 AM
Evo Tengoku's Avatar
Do you have extended studs?
Old Aug 16, 2011 | 07:43 AM
awd2gen's Avatar
Go to www.wheeladapter.com
For $150 you get two spacers that are hub and wheel centric and thickness you want.
Old Aug 16, 2011 | 08:19 AM
llDemonll's Avatar
anything bigger than ~5mm you should get extended studs
Old Aug 16, 2011 | 10:02 AM
Dallas J's Avatar
Veteran: Army
When I order spacers Ill order studs, right now theyre stock studs though.
One reason I want slide-on spacers over bolt on is that I didnt really want to run them on the street. Though, it probably wouldnt make a difference but I want to be able to remove them if Im not on the DOT slicks.
Old Aug 16, 2011 | 04:58 PM
BenJ's Avatar
Motorsport-tech
Old Aug 16, 2011 | 05:13 PM
Dallas J's Avatar
Veteran: Army
Originally Posted by BenJ
Motorsport-tech
Perfect! $70 + shipping for 2 spacers
Old Aug 16, 2011 | 05:27 PM
rodent's Avatar
I got a price of $130 for the pair from motosport-tech.
I'm currently running 22mm spacers with ARP studs for my slicks. They were bolt on but I pressed out the studs so they just slide on. Hub centric. $75 shipped on ebay and they use high quality alum. 1.25lb each. No problems trapping 135mph.
Old Aug 16, 2011 | 08:42 PM
Dallas J's Avatar
Veteran: Army
Hubcentric is probably why theyre more. I dont need hub centric for an autocross only wheel.
asu11
17
Feb 8, 2015 04:38 AM
gui dube987
12
Apr 27, 2014 04:42 PM
UncleXSO
26
May 19, 2010 03:04 PM
unclecomfort
Dec 16, 2008 11:16 PM
nubby
Mar 7, 2006 11:19 AM
