brake shutter is back AGAIN!!!
what brake pads are you using? sounds like classic uneven transfer of pad material,
Hit your discs with a scothbrite pad on a die grinder and I'll bet it goes away for a few hundred to a thousand miles.
You're not using your brakes hard enough.
I'm using centric premium rotors with stoptech street pads...I do have play when I wiggle the wheels at 12 and 6 o clock it sounds almost like a click and this is after I changed the bad tie rod and also have a horrible grinding shrieking noise when I'm driving above say 60mph next to a guard rail which is why I'm leaning towards wheel bearing...when I got an alignment last week I had them check the ball joint and they said it was good but that my top strut mount has play but would a bad strut mount cause a shutter? And even a steering wheel wobble during normal driving?
And to add my rotors are a uniform color all around pads are wearing even and there's no noticeable variations on the rotor meaning there smooth which is why I don't believe I need to re bed the pads as I followed directions to the T
if it went away after turning the rotors then you've got uneven break pad transfer on your rotors.
Did you bed in the pads properly?
read these articles. specifically the one about the bed-in procedures.
http://www.stoptech.com/tech_info/te...e_papers.shtml
I followed their break-in procedure which is basically take it easy for 1K miles.
I was curious if the aggressive braking method is fine for these ceramic pads?
Thanks.
I'm really leaning towards wheel bearing now...I have a horrible whining noise coming from the right side of the car and it's not like a t case whine it's like a high pitched grinding and I think that's what's giving me the constant shudder and the "feel" of uneven pad transfer on my rotors...
ive have noticed alot of people never suspect the wheel bearing simply because "they dont make noise". check for any play in them and might even want to check rotor runout with a guage on a fresh cut flat rotor. my wifes mazda also started doing it afte 90k miles.
RED DEMON
18
Jul 27, 2015 06:38 PM
sno_evo
25
May 11, 2015 12:09 PM
SLVRNBLK
45
Jul 30, 2008 12:13 PM
V Dub Mike
27
Jun 9, 2008 03:30 PM
Joes06MR
14
Sep 14, 2007 03:45 PM
