Alternative to bedding brakes, on freeway?
Is this a good idea? Sounds a little crazy but hear me out. I've done a lot of reading about the need to bed in brakes and the need to get the rotors progressively hot. Couldn't we mimic this on the freeway? What I'm thinking of doing is essentially riding the brakes to get them hot without slowing down for 4 seconds then release brakes and do it 25-30 times for the ferodo ds 2500....?
I used empty back roads late at night so there was minimal traffic. I would think your idea would work just gotta make sure you dont hold them for too long to start with so you don't overheat them.
Yea it would work... but i feel like your working the engine/turbo and clutch especially, too hard to do it that way. plus... my gut feeling, have you ever brake boosted... that **** sounds like the engine is gonna explode.
but i dont really know. id be curious to hear an actual knowledgeable answer. either way im gonna stick to the freeway method
Heat alone will not bed in the pads, you need to use them - bed them into the rotors - overheating them will cause them to glaze = poor braking power. You wont get the rears bed in with that idea, you wont be using the rear brakes hard enough.
How many sets of pads do you have?
All you need to do to properly bed in your new pads and rotors:
* Snub is the term used for the deceleration of a vehicle from a relatively high speed to a low speed using constant brake pedal effort.
** The location as to where the brakes are bedded is at the driver’s own discretion and entirely his/her own responsibility.
- 5 light snubs*, light pedal application: 50mph – 30mph
- 5 medium snubs, medium pedal application: 70mph – 40mph
- 3 hard snubs, hard pedal application (no ABS activation): 100+mph – 30mph**
- Cool down period – 5 mile run with very little brake (Do not sit at side of road with foot resting on brakes when hot, this is likely to damage the disc).
- Stop and examine discs – discs should show evidence of heat cycle (colouration in flange) and possess an even transfer layer of pad material on surfaces.
- Bedding procedure should now be complete.
I use this on all the pads I run:
Bedding Pads:
- 10 stops from 30 mph to 10 mph at half braking power.
Do not drag your pads during these stops. Drive for a few minutes.
- 5 consecutive stops from 60 mph to 10 mph under hard braking.
Once you're done. Drive home without using brakes as much as possible. Park car without the parking brake and let cool for at least 1 hour.
You may smell brake pads during bedding. Completely normal.
DS2500 has a working temp from 100-1000F. It's not the hardness of the compound you're trying to effect. It's the application of a fine film to the rotor and final burnishing of the pad compound (baking).
Let's put it this way, if the pad is not in the 100-100F range within the bedding procedure that I prescribe to then its not one that should be used on the street. (Race pads don't need that much abuse either. IMO Ferodo went overboard on their bedding).
