Coilovers in Winter
Old Dec 30, 2011 | 01:53 PM
bogoonthegogo's Avatar
Coilovers in Winter
Hi a newbie here,
Ive been searching and noticed people dont reccomand coilovers for winter since they rust. Are there coilovers that do not rust at all? Or are the spring and strut combos and perform just as well?
Thanks
Old Dec 30, 2011 | 02:04 PM
cfdfireman1's Avatar
Your car came stock with coilovers, of what do you speak?
Old Jan 1, 2012 | 09:14 AM
SW20Mike's Avatar
Veteran: Air Force
Pretty sure he means aftermarket adjustable coilover suspension. Just because the factory has a "coil" over a strut doesn't mean it's a coilover suspension in his question. I run KW variant and I drive year round, snow and all. Don't think they use salt on our roads, but I try to wash my car after the snow thaws and get the grime off the car. http://www.bonanza.com/listings/KW-V...Z-Z33/24250942 Further down in the link has a chart with picture comparison vs wear and tear.
Old Jan 1, 2012 | 09:19 AM
Sider's Avatar
I run Exe-TC on mine they have stainless bodies and cope very well with all the salt etc that they put on our roads, I think most "decent" makes are the same.
We have "Coilover Socks" available which keeps all the crap out of the springs and adjustment threads etc.
Old Jan 1, 2012 | 06:40 PM
Ohhhh Thanks for clearing this up
Old Jan 1, 2012 | 06:47 PM
ExtremeDSM's Avatar
Would never run any coilover in the winter. Salt and coilovers do not mix!!!
Old Jan 1, 2012 | 10:44 PM
SW20Mike's Avatar
Veteran: Air Force
You must not be reading the thread at all... besides, if you wash your car weekly it shouldn't be a big deal, salt or no salt. My coilovers are looking just fine
Old Jan 1, 2012 | 10:52 PM
alleggerita's Avatar
If you have to you can protect your coil overs with vaseline, grease, Boeshiled, etc. But ultimately chlorides (eg salt) is not an ideal environment for stainless - 316 is the better than some. You might want to read up on chloride corrosion and stainless steel
Old Jan 2, 2012 | 06:48 AM
ExtremeDSM's Avatar
1 person could was their coilovers once a week, another person could was their coilovers everyday, and the last person could not drive theirs in the salt. I will take the not driving them at all. If you do not get down there and scrubb every knook and cranny of the coilover, it will look nasty after one winter.
Old Jan 2, 2012 | 02:52 PM
Supraman522's Avatar
I bought a Sti once that had coil over's that had been in an area with a lot of snow and salt on the road's and they looked awful from corrosion!
Although with that being said a good hour or two of work and they can be cleaned up really good if you know the right stuff to use..
Old Jan 3, 2012 | 03:13 PM
GTijoejoe's Avatar
this is the wise thing to do.... personally I would probably coat them in axle grease
But that being said, I also don't re-adjust my height so I could care less.
Old Jan 3, 2012 | 03:37 PM
thatmr2guy's Avatar
Used coil overs is almost code for stripped because of corrosion. To the guy in New Mexico, while I think you might get cold your 'winter' is a vacation for people from Ohio.
Old Jan 4, 2012 | 07:34 AM
Thansk for all your input guys, I will have to think about thsi coilover situation because its cold here in boston and salt sucks
Old Jan 4, 2012 | 07:53 AM
GTWORX.com's Avatar
KW's are the only coilovers I would consider truly "winter proof" due to their construction. Some of the more recent AST, Ohlins, Bilstein, etc are pretty darn good in that regard, but not perfect.
- Andrew
Old Jan 4, 2012 | 09:45 AM
jdmpoirier4's Avatar
i wouldnt use coilovers in the winter, i'd put the stock shocks back on to make the ride hight better too since coilovers you probably dropped the car?
