18x9.5 Rota Grid tires and offset
Hey guys, I'm looking at picking up a set of Rota Grids. 18x9.5 I would like as wide of a tire as I can go and the most aggressive offset I can run. I'd like to avoid rubbing as much as possible (that noises like that annoy me). Like will it rub with people in the car etc? I have no problem with rolling my fenders. If I can, I'd like to be able to rotate my tires. Not a must but it's a plus. If I have to get spaces and upgrade bolt studs/lugs I will do so.
For instance, 18x9.5 +22 offset w\ 285/35 or 285/30's? Would that work? What can I get away with here? Can I have a more aggressive offset like a +18? What will rub and what won't? I'd be okay with a 275 or 265, of course a wider tire is better.
Thanks!
Thanks!
Trying to get you guys to use these calculators
+22 w/ a 285 certainly wouldnt fit my stock body EVO 9. Im rolled & pulled w/ bumper bolt relocation.
When I say fit, I mean your rear wheel/tire assy should be able to float fully into the rear well w/ no rub. Fitting aggressive wheels/ tires doesnt mean running out of spec camber or raising your coilovers JMO
http://www.rimsntires.com/specs.jsp
http://www.willtheyfit.com/
That is how I feel. I don't want to put some crazy camber so I can fit tires/wheels.
^^^You've got the right perspective
Who ever helps you fit your wheel & tire assy, you need to strive to achieve a full suspension stroke.
Remove the rear strut & articulate the assy fully through the suspension stroke & ensure no rub. Any form of rub can not be accepted
You want this:
Not this
You want this:
Not this
What specs are your grids?
I just read that R/TErnie makes end links etc.. He has succesfuly fit 295's and he is upgrading his rims from 10" to 10.5" on the stock body.
I am looking at running an autocross setup with 18x9.5 rotas with 285/30/18. Sounds like the +35 setup is the way to go with a spacer in front.
Are they charging for the full use of the rimsntire calculator?
After talking with R/TErnie I'm going to be running 18x10 +38 w/ 295/30. Reading his posts, he said on a 295 the tire was pretty wide on a 10" rim. I feel that a 10" would be perfect for a 285 rather than a 9.5.
Here is R/TErnies setup:
On a 8/9
20mm spacer up front
No spacer in the rear
Coilovers required
Removal of fender liners required
Hammering pinch welds required.
Depending on tire (285's and larger R comps) require a 6" spring up front
Under 285 size tires do no require a 6" spring.
Roll the front fenders
Evo Dave mod and run 2 degrees of camber... or No fender mod and run 3.5 degrees with a 295 wide tire as shown.
The rear has a minor roll job. I didn't come close to rolling the rears flat. No pulling in the rear at all.
Required - custom trailing link that I made for these to clear the rear links. Shown in Evo 8/9 FS thread.
https://www.evolutionm.net/forums/sa...condition.html
If the price is right I may be interested, PM with some prices!
I know some the mustang guys in stock class are squeezing 295/30/18's on their 18x8 rims. I am using the poor mans approach and looking at 18x9.5's that are more common and a little cheaper to run a 285/30/18.
