Ohlins coilovers installed
True...but I am not bashing any other systems (although cornerweighing has very little to do with ride quality). I would like to ride in the RRE/JIC's because I hear that they are nice. Corner weighing a car gives fabulous balance and predictability but doesnt change the damping curve of the shock/strut.
Originally posted by ogvw
They are the only "street" coilovers built by Ohlins (in sweden). Ohlins Japan offers the piggyback remote reservoir coilovers but they are not made by Ohlins - just "licenced by" Ohlins.
I can get these through my work. My company is the formula car Ohlins Dealer.
PM me for details
PM me for details
Originally posted by s4awd
Does it matter whether or not the Swedes manufactured it or the Japanese when the blueprints are approved from Ohlins Sweden anyway?
hueman said 2100 for suspension system that handles like stock....
True enought, corner weighting has nothing to do with the dampening ability of the shocks, it is only used to balance the
car (in terms of weight distribution) and provide an optimized center of gravity for the car.
Any coilover has this ability, the real magic of the ohlins is no doubt the shock absorbers.
Their motorcycle stuff is the at the top of the food chain.
Steve
Steve
Re: Ohlins coilovers installed
[B] The handling balance is very stocklike but less "busy" feeling - the car only rotates when asked. The difference is that the ride quality is sooo much better than stock.
that, to me, sounds like it's just more comfy and handles like stock.
initial impressions
So after a few days of driving on the Ohlins I am more and more impressed with them. I have had a chance to do an impromptu lunchtime autocross with Jim Russell Racing School( the benefits of working at Infineon Raceway ) and some spirited driving on canyon/Bay Area backroads. The car is so much more surefooted now. Mid corner bumps that used to make the car "skip" sideways are not even an issue anymore. Theres more traction exiting corners under full power regardless of road condition. I have increased the rebound/compression clickers from the baseline settings with good results. This is seeming to be a win-win suspention upgrade, better handling and more comfortable.....if only they were a bit cheaper (oh well, 2 out 3 aint bad). I'll be using them at Thunderhill Raceway Park on Feb 8th and I'll review the on-track handling after that.
This is good feedback, the stock suspension does feel very skippy or skaty... sometimes you feel like the car is gliding instead of glued down to the road.
Also sharp bumps make the car react violently, I bet the stock shocks have too much high speed compression dialed in. The rebound is fine though.
My guess is that the japanese roads are silky smooth
Originally posted by JT-KGY
I thought Ohlins cost around $10k???
and the last Ohlins coilover I saw has front shock reservoir that
goes up into the engine bay through the shock tower mounts...??
front - 46 HMRX
rear - 46 PRX
OUCH!!
Anyone know the spring rates on these ohlins setups??
Those are the rally shocks, $2400 each on the fronts and $900 each on the rears!
front - 46 HMRX
rear - 46 PRX
front - 46 HMRX
rear - 46 PRX
Originally posted by e8
after relooking over the coil over, it seems that ride height and preload are affected dependently.
Each shock comes with two blue 'rings' at the bottom of the spring. The upper ring adjusts pre-load, the bottom ring adjusts ride height independently.
Somebody please correct me if I'm wrong.
