Ohlins coilovers installed
Old Apr 21, 2004 | 03:10 PM
  #61
ogvw's Avatar
believe me wtz........ stiffer rear springs increase OVERSTEER, stiffer front springs increase UNDERSTEER (all other things remaining the same)
Old Apr 21, 2004 | 03:21 PM
  #62
steve_evo's Avatar
Originally posted by wtz
When I first tracked my Evo with stock suspension it lifted the inside rear wheel on turn-in, rolled like a Cadillac and understeered off the corner so badly that easing off the throttle was the only way to keep it on track. This is not the balance that I would want to preserve. The car was made softer for the US market with a generous helping of understeer. I understand what you're saying with regard to wheel rate, just not sure I agree.
Cheers,
The EVO8 rates are the same for japan, understeer is inherent in almost all cars, it's a safety factor for the average driver.
Adding spring to the front of the car will reduce mechanical grip and increase understeer, assuming no other changes to the car.
This of course depends on what kind of tire you are running, the amount of downforce, the sprung weight of the car. This is why racers run different rates than street cars, of course the race cars are setup much differently too.
FWIW, some local guys here in california have had some good track times with the EVO with just stock suspension.
How does 2.13 min.sec at Thunderhill sound? Or how about 1.58 min.sec at Sears point?
Steve
Old Apr 22, 2004 | 04:25 AM
  #63
wtz's Avatar
wtz
OK you guys, I'm not going to disagree with what you have said about the effects of individual components on the Evo's handling when certain other components remain stock. This is not the case with my car. My car has been lowered and corner balanced. I am running 9kg springs in front and 8kg rear with coilovers. I run an adjustable 25mm rear swaybar with adjustable endlinks. I have a Torsen-type front LSD. I run -3 degrees of camber up front, -1.5 rear with 0 toe all the way around. Lighter race wheels with a wider front track, Hoosiers, lighter rotors etc, etc. I ran the car at Limerock in this configuration. The rear bar was set in the middle holes. Tire pressures were 41 degrees hot on all corners. The track is bumpy and I found that I could only use something less than half of the available damping on the shocks. This leads me to believe that these spring rates are higher than neccesary on most tracks in the Northeast. The car turned in crisply and kept its tires on the ground. Mid-corner balance was almost neutural with some understeer on corner exit. I believe this could be tuned out with the rear bar. Even though I am running a softer rear spring vs front, the addition of the bigger rear bar ups the rear wheel rate. Maybe someone could work out the combined effect of spring and bar on wheel rate? The first thing I noticed in the stock Evo was that most of the understeer is caused by excessive body roll. The stiffer rear bar helps immensely and I believe it to be the best first handling mod. Since I believe the rear bar change to be a mandatory starting point to improving the car, this lead to my original question regarding slightly more spring in front vs rear.
Cheers,
Old Apr 22, 2004 | 11:27 AM
  #64
steve_evo's Avatar
Cheers,
First of all, it is very difficult to judge what if anything could be wrong with your car. Also, handling is subjective to the driver, meaning someone may think your car handles fine when they drive it, but you may think it needs tuning. Also what type of coilovers are you running? Does the car have more/less weight taken off?
In general, a swaybar depending on where it is located, it's size and diameter will add more torsional rigidity than a spring will. It is a good tuning tool to dial the car in at a specific track or if you want to change the transient handling nature of the car.
Body roll does not cause understeer. Even with really stiff springs/swaybar, a car will still transfer it's weight in a turn, it's just the rate at which it will transfer it's weight that is affected.
Steve
Old Apr 22, 2004 | 11:41 AM
  #65
wtz's Avatar
wtz
There is nothing wrong with my car. Sorry I got involved in this thread. Will find answers elsewhere.
Old Apr 22, 2004 | 05:34 PM
  #66
redvolution's Avatar
Getting back to Ohlins, they make the best motorcycle forks and shocks. Absolutely top-notch. For $2k+ I'd want independent rebound and compression damping tho...
Old Apr 22, 2004 | 11:08 PM
  #67
ogvw's Avatar
wtz.... I appreciate your input and it is certianly valid, keep it coming
redvolution... true double adjustability cannot be had for less than $3-4K per set....
Old Apr 23, 2004 | 03:24 AM
  #68
wtz's Avatar
wtz
Thanks OGVW,
Nice chatting with you yesterday. If you want to know more about my diff, do a search for "Front LSD installed". Maybe Steve is right, body roll does'nt cause understeer. But it sure as hell accentuates it.
Cheers,
GTWORX.com
EvoX 'For Sale' Suspension / Brakes / Handling
54
Jan 21, 2011 10:02 AM
GTWORX.com
Evo 'For Sale' Suspension / Brakes / Handling
108
Jan 7, 2011 09:55 AM
evo_soul
Toronto Lancer Club
Sep 11, 2010 05:51 AM
RallySport Direct
Feb 11, 2008 08:39 AM
ogvw
22
Dec 20, 2003 08:43 PM
