Lower sub frame braces ?
Old Mar 15, 2012 | 03:04 PM
mcm308's Avatar
A while ago when I installed my 3" turbo back exhaust I had to remove the lower braces to install the DP. 3 of the bolts snapped no big deal.. I can drill and retap. I noticed though that the flimsy factory braces wouldn't really work any more with the larger DP so I never put them back on but now I want that area fixed. Is there any aftermarket sub frame braces that will clear big DP's ? I can fabricate myself if need be but want to see what others have done. I'm sure I'm not the only one who encountered this.
Old Mar 15, 2012 | 03:07 PM
SilverShadow03's Avatar
I have a 3" TBE and the two braces you're talking about fit just fine with my dp. You have the spacers right? Mayber you can get longer bolts and put in a couple of washers to give you the added room needed....
Old Mar 15, 2012 | 03:16 PM
llDemonll's Avatar
I had to stick two washers in mine to clear the DP, ~1/8"
i may see if one clears next time i chance my oil
Old Mar 15, 2012 | 03:19 PM
mouseIX's Avatar
My Buschur exhaust came with metal spacers to drop the cross braces enough to clear the exhaust.
Old Mar 15, 2012 | 03:29 PM
sujinX's Avatar
spacers work for me, i think i just got 2 thin ones from the hardware store. or maybe just 1...
Old Mar 15, 2012 | 04:11 PM
Dallas J's Avatar
Veteran: Army
Spacers here too. Also I put on a heater hose slit in half around it where the downpipe is held on with hose clamps to prevent any rattling. After 2 years it hasn't melted so I'd call it good.
Old Mar 15, 2012 | 05:09 PM
mcm308's Avatar
Yea, I thought about spacers but if I recall, I was looking at about 1/2", possibly a little more and I didn't want these things or the bolts protruding from under the car so that's why I didn't take that road. Like I said, those bars are kind of cheesy anyway, can't really see them serving any useful purpose.. I could be wrong though..
Old Mar 15, 2012 | 06:29 PM
llDemonll's Avatar
your fitment is way wrong if the crossbrace needs to be lowered 1/2". ideally it shouldn't be lowered at all and should be clearing a 3" downpipe. mine just barely rubbed
Old Mar 15, 2012 | 07:17 PM
BluEVOIX's Avatar
I'm running the MXP 3" downpipe (RRE also sells it under their name) . This downpipe clears the ACD and chassis brace without any need of spacers.
I've had all different brands of downpipes and this was the most perfect fitting one there is. It is also a well built with quality flanges item.
To answer your question:
In the past I've either used the spacers the downpipe manufacturer included or ran multiple washers for clearance.
Old Mar 17, 2012 | 09:20 AM
johnnydemz4G63's Avatar
Have the same problem with A invidia DP rattles like crazy at idle, I will try some washers and see if that clears it enough.
Old Mar 17, 2012 | 02:40 PM
Dallas J's Avatar
Veteran: Army
I just double checked mine and I dont have any spacers with an ETS 3" downpipe. I do have the rubber on there to prevent any rattles but no spacers needed.
Old Mar 21, 2012 | 02:32 PM
Jeff_Jeske's Avatar
I've had those bars off for years.... they barely do anything when mounted right and do next to nothing once spaced with washers and such.
umiami80
Aug 3, 2016 09:34 AM
Por2geezSupra
Dec 9, 2007 10:59 PM
Z1 Performance
Evo 'For Sale' Suspension / Brakes / Handling
Dec 13, 2005 03:01 PM
pgmike
17
Feb 20, 2005 10:58 AM
BigAeVo
Aug 31, 2004 12:31 PM
