Swift Spec R springs question
Old Apr 13, 2012, 07:40 AM
thedru13's Avatar
I am ordering Swift Spec R springs today for my IX MR. Stock BBS MR rims. My question is what else should I have on hand for the install? Bolts ect. Also does it make sense to order Camber plates and pillows for the rear? IF so what brand do people suggest. thanks everyone
Old Apr 13, 2012, 09:34 AM
HaVoC187's Avatar
Check this how-to on doing springs so you know what you will need.
http://www.evomoto.com/tech_info.php..._12&tech_id=22
Old Apr 13, 2012, 09:39 AM
thedru13's Avatar
Thanks I did read through that. I thought for the swift springs you didnt need to replace the bump stops..
Old Apr 13, 2012, 09:55 AM
llDemonll's Avatar
you dont
Old Apr 13, 2012, 11:36 AM
thedru13's Avatar
Originally Posted by llDemonll
you dont
TY... So is it worth runing camber plates?
Old Apr 13, 2012, 11:50 AM
llDemonll's Avatar
only if you need to adjust camber. unless you did something weird though you won't be rubbing on anything so you won't need to adjust camber (if you autox you might need this adjustment)
Old Apr 13, 2012, 12:28 PM
thedru13's Avatar
Perfect. I have coils on my VW and can adjust camber with out plates wasnt sure if the Evo would pose an issue. Appreciate the input...
Old Apr 15, 2012, 07:17 AM
byt
byt's Avatar
The factory eccentric bolt allows adjustment to -2*. Get camber plates if you need more camber than that.
Old Apr 15, 2012, 08:05 AM
bhmax's Avatar
I could get -2° camber on stock springs but only -1.5° on spec Rs with the stock strut bolts. Installer said he normally takes additional regular bolts and grinds them down as needed to get the desired camber, but I've just stayed with the -1.5° for now. I might look into that or camber plates in the future.
JDEve
May 6, 2015 06:48 AM
eVoRox
Jun 9, 2014 07:28 PM
stealthyevoviii
Oct 20, 2011 01:20 PM
Dr.Sound
63
Nov 22, 2010 04:40 AM
evil.evo
Aug 9, 2010 02:23 PM
Quick Reply: Swift Spec R springs question
