Size of threads on In/Return of Power Steering Rack
I would look into JIC and hydraulic lines... basically make it a hydraulic setup you see on construction equipment which ranges from 3,000-5,000psi and I don't know if the power steering exceeds that, but they also make 10,000psi line with JIC. Go to any hydraulic house and they can set you up if you know the sizes of the fittings, or if you have the fittings in hand. They also might be able to get you adapters to go from pipe thread or whatever the stock lines are to JIC. It might not be cheap so to speak, but it would be done correctly.
I wasn't planning on doing an AN fitting. I was doing a premade high pressure line with a M16 banjo fitting on the end so you can utilize a banjo bolt which I believe is what was on there already.
and.. so can you help me out with the low pressure side fitting size?
allevolution
Aug 18, 2022 12:52 PM
PureDsm
May 12, 2017 10:58 AM
Dan@Assaultech
73
Oct 10, 2011 02:02 PM
