help tire noob here someone help
Old May 23, 2012 | 10:46 AM
turbodsm420's Avatar
hey I have 17x9 wheels w/ +25 offset and a evo 8 what size tire should i buy? I have 245/40/17 and dont like them, These will be for autocross on weekends and drive to work so i dont want any rubbing issues. any input is helpful
thanks
Old May 23, 2012 | 01:50 PM
Neal@tirerack's Avatar
Don't like the size or the type of tire? That's a good size to use, but there are others using a 255 on a 9" wheel. Not sure if they have any rubbing issues with that offset, however.
Old May 23, 2012 | 03:47 PM
Yea I read that it's a smaller tire size than oem. Someone suggested 265/40/17 can someone confirm it will fit without rolling all my fenders I want to buy tires today.
Old May 23, 2012 | 06:39 PM
RAbo's Avatar
Tire Noob (2)
I have the stock setup at the moment... on my 2.0 de...
Wheel Width:6.5Tire Profile:60Tire Width:205Tire Diameter:
16.0Front tires: 205/60HR16.0Rear tires: 205/60HR16.0
WTF does all of this mean!?!?!
I need a breakdown, i need pictures of nice setups, i need tips and ideas..
Here is the breakdown of what i would like ----- 17 or 18in rims... bronze preferrably.. I would like low profile tires but wider stance ... i don't want to have to install anything else so im staying away from camber kits and whatnot... (even though the car is fatter at the back and dumped it would look nice without looking so straight, ya kno?)
Thanks for reading.. looking forward to some good ideas and what type of numbers i should be looking for!
PS i like some of the things iv seen at Tire Rack.com, but i dont know if i order a wheel + tire package, if i can change the tire sizes.. bad enough i dont even know what the numbers mean.......
Old May 23, 2012 | 08:10 PM
You would need a roll & pull w/ that tire spec IMO. Dont be shy or faint of heart, its OK to roll & pull to make clearance.
Only way to get the EVO looking wide & aggressive
Get some solid, experienced help & get it done right
Old May 25, 2012 | 02:04 PM
rawkus's Avatar
A 265/40-17 isn't a common size and I wouldn't recommend it for a 9" wide wheel, though honestly I doubt anyone makes a decent tire in that size. The most common tire size you will see is a 255/40-17 and Hankook, Dunlop, Toyo, Falken, Bridgestone, Yokohama, Kuhmo ect... all make quality autocross style tires that work in that size. That being said, with a 25mm offset, it will probably rub in the rear without rolling the fender. You might have to go with a 235/45/17 (OEM size) to have a tire work without rubbing.
Dan
Old May 25, 2012 | 02:08 PM
rawkus's Avatar
Wheel Width is 6.5"
Tire Profile is 60 aspect ratio (aspect ratio is percentage of TIRE width)
Tire Width is 205mm (so tire profile is 205mm x .60 (60 percent of width))
Tire Diameter is a typo... I think you mean Wheel diameter which is 16"
Front tires 205/60HR16.0, 205mm tire width, 60% aspect ratio, H is speed rating, R is Radial, 16 is 16"
Rear is the same...
Does that help?
Dan
Old Jun 26, 2012 | 07:13 AM
My car has coil overs and the fenders are rolled a little already I was just wondering if I would have any other figment issues. I was considering a taller tire because I have a lot of wheel spin in first and second, but I heard a 255/45/17 won't fit because it's to tall. I think I'm going to buy the handkook rs3 245/40/17 From tirerack unless someone can convince me to run a different tire size.
Old Jun 26, 2012 | 07:28 AM
grillpt's Avatar
If you have a 9" wheel I highly suggest a 255/40/17. If you're a drag racer you may want to go with a 245/45/17 as this will give you a little taller gearing. I'm not here to convince you of anything though, its your car, do what you'd like.
Old Jun 26, 2012 | 12:20 PM
It is a 9" wheel. I drag race and auto x every weekend and it's a daily driver I just wanted some input on what other people use Before I spend a lot of money. Thanks guys
smithrcing17
Sep 29, 2009 08:54 PM
empire060
Nov 15, 2008 01:59 PM
Mortis
For Sale - Wheels / Tires
Feb 12, 2008 07:43 AM
joberk3
17
Jan 11, 2006 08:38 AM
ewsang
15
Jan 15, 2005 09:10 AM
