Wheel spacers for Evo8!
What "mm" size should I use if I have the stock BBS wheels on my Evo8 and just want a wider stance for looks, after I lowered her, the wheels looked a bit recessed. I've been seeing 15mm on perrinperformance, but then called jegs, and they were trying to get me into 1 1/4 in.! so idk..anybody know what size would just make the rim sit just inside the fenders with out rubbing?
^^ i think that is definitely bad for your drivetrain.
throttledrop, 20mm spacers should be perfect depending on the size of tires you're running. 235/40/17 doesn't require any fender work ... if you're using wider tires, you might want to roll your fenders
i found some cheaper for you ... check it out http://www.ebay.com/itm/ICHIBA-V2-WH...ht_2481wt_1270
