I hate to make this thread - yes I've searched (front sway bar)
I searched for a couple days now gathering information but I still can't make a decision.
I have Fortune Auto 500 series coilovers and nothing else as far as suspension goes, I don't currently track the car but I would love to do road course one day. I only drive on the street but I love to drive aggressively and take on-ramps and back country roads really fast
Anyways, I have the subframe out of the car for a clutch/tranny build and if it's recommended to change anything on there I would love to do it now as opposed to later when it's back on the car and a pain in the ***. I've decided on a whiteline 26mm front swaybar, any input on this would be greatly appreciated. If it's not necessary then I'll just put it back in stock, but if it's something you guys recommend then I'll spend the money now and save the headache later
thanks in advance
thanks in advance
Hey, Im just a junior member of this suspension forum but here's my .02
My suspension tuner (Muellerized) frowns on FSB's due to front tire lift (Not a good thing on an AWD sports car) & does not recommend them unless other higher end suspension mods have already been done (Not a good thing on an AWD sports car)
Most of the suspension heads here on this forum will probably tell you to do it while your at it. Whiteline
EDIT^^^
EDIT^^^
EvoM Community Team
I recommend what Peter*g told me about FSB based off of what Ralliart does for their cars that run on the tarmac.
Nothing against your suspension tuner, since I have no idea how much experience he has, but I trust Ralliart and the amount of race experience they have especially with the Evolution platform.
As with any suspension set-up, you need to ensure you do everything as a complete package as the parts need to be tuned together as a system.
I ran the Whiteline 26mm front / 24mm rear. I attached the recommended suspension specs from Ralliart for tarmac events. The recommend up to a 27mm front bar. The fat front bar keeps the front roll under control and lets the front tires work better.
so what I gathered from that is if I do a front sway bar, I should also do the rear to keep things balanced?
front 26mm, rear 24mm? Whiteline, or another brand? There is a special on another forum for any suspension products today only so I would like to make a decision today
The front swaybar is an awesome upgrade...as good as the rear IMO if done appropriately. If you're in there, it's a worthwhile upgrade if you're looking for a bang for the buck improvement. If you're happy with the way your car handles now though then don't worry about it, this would just improve things.
- Andrew
- Andrew
^ that.
Whiteline front and 24mm adjustable rear.
Now - do you need it? First - stop upgrading the car before you go out for a track day. You already have too much car to push 11/10ths. Learn the car as-is -- then modify it appropriately from there.
My .02 as a racer and instructor.
Front sway bar decisions need to be made around front roll. Do you have enough spring to control roll? How low is the car effecting roll moment? How much camber do you run? How sticky are your tires?
There is no one answer. More front grip will cause more front roll which may cause less front grip. Grip stops when tires aren't happy, either from decreased camber or too much weight transfer. My method on a street car is to reduce roll. At least the perceived difference will feel better.
On my car though, crank up that front spring rate and soften the bar. You dont want to DD my car...
