Tein flex with EDFC
Old Aug 12, 2012 | 06:17 PM
Smike's Avatar
Old Aug 13, 2012 | 12:34 AM
explicitcarclub's Avatar
I'm running Evo X 18" enkies what tire you recommend ?
Old Aug 14, 2012 | 06:32 PM
quick question guys, do the Swift Spec-r springs come all black? i thought they where gray(blueish) because i got mine today and the look like a knock off!! thanks for your help
Old Aug 16, 2012 | 09:32 PM
Just installed them and I love them!!! ride is great and looks fantastic, tomorrow off to the alignment rack!!! thanks for everything guys!!!
Old Aug 17, 2012 | 02:31 AM
Smike's Avatar
They are black now.
Great to hear! Enjoy!
Old Aug 23, 2012 | 03:39 PM
Seto519's Avatar
Originally Posted by WRC-LVR
Yes sell the teins quickly. then use the money to get either GTWorx or Swift Spec-r springs and a decent rear sway bar. Source a good adjustable rear sway 24-25 mm ( Whiteline, Progress, Hotchkiss )
Don t worry about the height. Use the stock Bilsteins if they are still good and pair them with either GTWorx springs or the Swift Spec-R's. Install the rear bar and put it on the middle setting.
Finally, get a good alignment from a competent shop that knows Evo's Specs should be zero toe all around -2 camber up front and -1 camber in rear.
Then enjoy the real upgrade you have just performed.
If you want the best out of the car after that, get some Rs3 or star specs in 255-40-17
L8r
i think i will go with this also. sad that previous owner put on tein springs instead of the swift specr r on the MR struts.
Old Aug 2, 2013 | 09:30 PM
NorCal Lancer's Avatar
Anyone have experience with the Tein Flex Coils with EDFC? For those of you who installed the EDFC, any advice on how to hide the wiring? Underneath the carpet? I got a killer deal on barely used Type Flex Coils with the EDFC unit. I plan on getting everything installed within 1-2 weeks.
sdotsluggz
Jan 7, 2012 03:53 PM
evoforstevo
17
Apr 21, 2011 03:45 PM
4g63 gsr
Feb 25, 2010 03:12 AM
Evo H8
35
Oct 16, 2006 05:54 AM
V8EatEr
Nov 7, 2003 02:04 PM
