Tire Dilemma
Old Jul 31, 2012 | 04:27 PM
EvoIIIAj's Avatar
Tire Dilemma
Alright here's how it goes.
I need 2 tires (because the car needs alignment which will be done) but I can't find the size I have on now on island. I run 235/45/17 on IX BBS wheels, Toyo R1Rs.
All I can get is 245/40/17 in the R1Rs, I would just change all 4 if that's the case because i'll be able to pay down on them.
I do a bit of autocross, maybe once a month max, what do you guys think about the 245/45/17 fitment compared to the 235/45/17?
Old Jul 31, 2012 | 04:35 PM
Raptord's Avatar
I'm running 245/45 Kumho Ecsta XS'. wanted larger diameter for highway cruising & slightly lower rpm at the top of 4th at the road course I usually run. Little bit of rubbing on the inner fender at full lock, but nothing dramatic.
Old Jul 31, 2012 | 04:37 PM
EvoIIIAj's Avatar
Is that on stock height or lowered? My car is lowered a bit
Old Aug 1, 2012 | 04:27 AM
mouseIX's Avatar
I run OEM 235's on my street tires. But for autox and track events I use 245/40r17's on the OEM wheel. But tires are different. In that size the my Kumho V710's were about 1/2 wider than a Dunlop Z1 star spec. Either way do some research on tirerack.com they list specs on tire widths. You should be fine with a 245/40r17 R1R.
Old Aug 1, 2012 | 05:43 AM
Raptord's Avatar
RCE springs so slightly lowered as well.
Old Aug 1, 2012 | 07:31 AM
Neal@tirerack's Avatar
The 245/40's will work fine, but don't mix the sizes. Diameters are different and you could mess up your drive train.
Old Aug 3, 2012 | 07:05 AM
ODUB's Avatar
if you run 245/45's and you autocross the car, you will rip your fender lining out...ask me how I know. 245/40 works, but it's a little off. the best upgraded size for stock wheels is 255/40 if you can get them.
Old Aug 3, 2012 | 07:23 AM
meckert's Avatar
Have you thought about ordering what you want from tire rack? Yeah, I know there is shipping involved, but it solves the immediate issue of size and varying opinios..
Smike's Avatar
Not true. Depends on what suspension you have.
I ran on Swift SpecRs with 245/45R17
Old Aug 3, 2012 | 07:40 AM
EvoIIIAj's Avatar
I checked Tire Rack yes... I think I will just buy 4 245/40/17's if they have them in stock here on island. Duties always kill us when importing items so we try to fInd what we can on island..
I won't be mixing tire sizes for sure.. I know the 245/40 shouldnt rub height wise but not sure about width wise? I'm on Fortune Auto 500s so I can adjust if needed also. This is the height of my car:
Old Aug 3, 2012 | 07:49 AM
ODUB's Avatar
good point. I was lower than swift specR's, and 245/45's didn't work well for me at all. 255/40's worked perfectly, and I've run that size ever since. The 245/45's didn't even look right, and i didn't like the way they felt. Too much sidewall.
Old Aug 3, 2012 | 08:11 AM
Smike's Avatar
Lowered cars require careful fitment choices.
Sidewall differences:
110 mm (4.3'') to 102 mm (4'').
IMO, could have been other factors or changes. Can you 100% say 0.3in difference in sidewall was the causal explanation?
Old Aug 3, 2012 | 08:23 AM
ODUB's Avatar
nope...it was height coupled with the stiffness of the suspension, but almost a half inch difference makes a difference lol I never had an issue with the 255/40
Old Aug 3, 2012 | 08:38 AM
Smike's Avatar
8mm is hardly a difference.
Being that lowered, I be you were only *just* off the fenders.
Old Aug 3, 2012 | 10:46 AM
Davo's Avatar
i'm on gtworx with cooper rs3-s in stock size and rubbed on auto x-ing
S1MPSONS
For Sale - Wheels / Tires
Mar 28, 2012 08:23 AM
It'sMe
11
Jan 5, 2012 04:29 AM
Grippy Tire
EvoX 'For Sale' Wheels / Tires
31
May 19, 2011 08:31 AM
Nomad4g63
20
Feb 19, 2010 10:52 AM
Neal@tirerack
Evo 'For Sale' Wheels / Tires
226
Sep 8, 2009 07:24 AM
