Strut question
Old Aug 16, 2012 | 06:43 AM
redridingboost's Avatar
Strut question
Ok so a WHILE back i got a set of struts and Tien springs installed on my car, recently (yesterday) i blew the driver side front strut and decided to run to the parts store to replace it. To my surprise the part I received was WAY smaller than what i have on my car SO........... question
Are Evo 8 and IXs front strut the same size?
Are all Bilsteins Yellow?
Is it possible that I have KYBs if so who sells them? The only kyb im finding are for the lancer models. Would that fit?
Did they give me the wrong part? (Spring is too big, wont fit in the base)
You knowledge will be appreciated
Old Aug 16, 2012 | 09:18 AM
Jim3142's Avatar
The dampers from the 8 and 9 should be the same size as they are interchangeable, and all Bilstein MR dampers are yellow. The KYBs are usually black with a yellow stripe near the bottom. Hope that helps.
Old Aug 16, 2012 | 09:21 AM
n2oiroc's Avatar
they gave you regular lancer parts. you can not get any struts for an evo at any parts store. only ones you can get are oem kyb's and mr bilsteins from the dealer, or bilstein hd's from a few sources.
Old Aug 16, 2012 | 10:05 AM
Smike's Avatar
Tein springs? Prepare to be replacing struts often. They are too low and too soft.
Oh wait...you already blew one...seriously. They are that bad. Go back to OEM or Swift/Robi/GTWorx.
You have a Lancer strut. Evo OEM are $400-600ea at a dealer. KYB used $400 for a set with low miles (hard to find now). MR Bilsteins used are $450-500 (also hard to find). HD Bilsteins are $800 (new) and on back order.
Old Aug 16, 2012 | 10:44 AM
LOL @ Smike, i really dont have an issue with them. This is the first time im changing a strut on my car in 2 and 1/2 years. Its not my everyday and I dont rag it out. SO im cool wit it.
Old Aug 16, 2012 | 11:23 AM
n2oiroc's Avatar
seriously, you dont know what you are missing with them. swap to some swifts and you will see the light.
Old Aug 16, 2012 | 11:49 AM
maevo8's Avatar
I have some stock struts if thats what your looking for pm me if interested in it .
Old Aug 16, 2012 | 05:35 PM
Smike's Avatar
LOL @ you.
Yes, you do. What do you they blew the strut? And if its not your everyday car then 2.5 years means ****. Its just physics and some science. Too low and too soft. Your struts valving was beaten into the housing.
Hey, I'm just a guy (scientist/engineer) that did work on this chassis. If you like the level f medication you're on - stick with the dosage.
beasters
Dec 24, 2012 12:51 PM
Heebs 09gts
Oct 27, 2012 10:48 AM
Ralliart367
15
Sep 7, 2012 07:46 AM
iitzbebo
Oct 11, 2011 06:50 AM
nashvilleRA
10
Aug 11, 2010 10:33 PM
