Would you guys replace these pads?
I'm sure most answers would be "yes, might as well, got the car up already anyway." But can I eek out a few more thousand miles out of these? I hate to toss stuff prematurely, and I'm a pretty sedate driver.
I'd say there's about 5 to 6mm of material left, the manual lists the limit at 2mm.
Do you say that because the car is already up, or because this is low wear for a car? This is my first car, I've mostly dealt with bikes, so I don't know what "close to done" a car pad is.
Its an easy job on the Evo. Since you have it up now, might as well address (not with auto parts store pads either...).
Lower the pad material that remains quicker the pads heat soak. And if you wear them to the metal plates and those hit the rotor; you'll be looking at rotors too.
Stoptech Street pads are a good DD/sport replacement.
Thanks. I already have some Hawks, so I'll just get her done tonight.
What's the best way to push the pistons back without taking the caliper off? I don't want to leverage a screwdriver against the disk. I do have that tool with the long thread, but I don't think it's useful for the Brembos.
On a purely street driven car about 3mm I would say to replace by. If you regularly drive 'spirited' then I would replace about where your at now.
The inside pad had much less life left, so I changed them out.
That got me thinking: what causes that and can you rotate pads on each side to even out the wear?
l8r)
bvliz
Nov 16, 2016 03:55 PM
WTT[West]: Gruppe-S 52mm gauge pod
hooliganSKATE
Mar 12, 2016 09:20 PM
mrfred
14
Jan 13, 2015 05:30 PM
Great pads to have.
