Street Tire Pressure
What tire pressure do you run on the street? If you respond please toss in what model/size rubber your run.
I have a stock sized set of Nitto Invos on right now, they're reaching the end of their service life soon. I had them on the rack the other day and one of the tech's pointed out that they looked 'bulged' around the belts. He thought it could be from over inflation. I thought that was doubtfull seeing as I've never inflated them above 40psi and they max out at 51.
How would you rate them from a daily driving standpoint. I've heard they're solid crossover for AutoX.
Great in rain as well. Pair them with decent pads for a real eye opener :-)
They will not hold the road well below 32F, my only real disclaimer. Then again you will be taking them off up North for the Blizzaks
My standby are Hawk HPS pads, what do you prefer?
It's probably in a thread somewhere else but a few of you replied that you run less pressure for autoX.
I seem to recal reading that you should go up in pressure to lower the amount of deflection in the tire..... it's been a while though.
If I am driving on the street I will run 34 cold front and 32 cold rear. If I am auto-xing I will run 35 cold all around. When I auto-x I check the tire pressure after each run. I make sure I keep it at a consistent 35 psi on each tire and bleed off extra air when hot.
High tire pressure will start to make the tire buldge, which will reduce its grip.
Low tire pressure will make the tire roll over and make it spongy on cornering... for example, sometimes you'll see ppl mark the sidewall of there tire. This will allow you to see how the tire is rolling, you shouldn't be wearing your sidewalls
smoothevo
Aug 9, 2010 10:17 AM
Inflation
Aug 22, 2008 06:37 PM
