Strange noise from front left
I Have no clue what it is but its quite annoying but whenever i hit even the slightest bump the left front makes a wobbly noise or even if the car is parked and move around ALOT on the inside to shake it
Maybe you guys could identify my problem
First I would check to see if anything is broken, then, I would check to see if anything is loose. Grab hold of everything connected to the front left wheel, and shake it. See if you can replicate the noise. Tie rod, ball joint, strut mount, are 3 of the things that come to mind when you mention loose/wobbly noises from the front end. give the whole things a once over and report back with the findings.
MISHI
20
Sep 6, 2013 06:43 PM
kevin10
Lancer Engine Tech
Mar 31, 2013 09:49 PM
Malik_EvoIX
20
Feb 20, 2009 11:10 PM
