Stoptech pads and OEM shims
I'll start first with a short overview. Im swapping the brembos onto a different car other then an EVO. I have brand new Stoptech slotted rotors going on the car. I'm using EVO 8 calipers with a new set of Stoptech pads
Im reviewing this post:
https://www.evolutionm.net/forums/ev...rake-pads.html
However, It seems my Stop tech's have backing plates on them and im wanting to know if i should get the OEM shims ( i do not currently posses them). It seems brake squeal is a large problem without these shims as well, so i may be answering my own question, im just looking for experienced Brake advice/guidance.
something like this:
http://www.mitsubishiparts.net/catal...ction=856#2166
Looking at this, https://www.evolutionm.net/forums/at...995ab00usa.gif
it looks like i need the shims? Thanks for your help!
Well, yeah, I've always used the OEM shims and have never (knock on wood) encountered a noise problem. However, a fixed caliper braking system is prone to noise. Anything that triggers vibration can cause this - anything, like perhaps slotted rotors.
Those links provided previoulsy, are those for the stock shims?
I saw lancershop carries some OEM shims for like $70.
http://www.lancershop.com/customer/p...productid=1425
Which seems to be a little high.
I was wondering what does anyone else consider "OEM brake shims." Unfortunately, I got my Ferrodo DS2500 brake pads in, with slotted RotorPros, and they seem to squeal a lot. I did add the "anti-squeal" grease to them, but the noise is still abundant. So I am considering adding brake shims to the pads, to hopefully, quiet them down at least during normal traffic.
Thanks
Thanks
