Offset Question for TE37
Old Jan 14, 2013 | 10:30 AM
skevo8's Avatar
Has anyone ever tried to run this set up on their evo?
18X9.5 +22 Front
18X9.5 +0 Rear
with 245/40/18 nitto555
is it possible to make them fit with a -1.5 rear camber for the rear?
Old Jan 14, 2013 | 12:41 PM
llDemonll's Avatar
18x9.5+30 will make the rears sit flush; you're going to need rolled fenders at the least and either a nice pull or a lot of camber. i doubt they'd fit with -1.5; if they do it will be really close
Old Jan 14, 2013 | 12:55 PM
ReidFletcher's Avatar
I had to roll pull and flair my quarter panels about 1.5" to fit a 9.5" +22 w/245/40/18. That was at about 1.3' camber in the rear. With the extra inch almost of offset you'll need a TON of camber and fender flair. Wait.. This is on an evo 8/9? Or X?
Old Jan 14, 2013 | 01:00 PM
SmurfZilla's Avatar
I would imaging 2 different offsets would play havoc with your diff's
Old Jan 14, 2013 | 01:24 PM
This setup @ +22 required alot of work to fit. Imagine poking out another .87"
BTW, Alot of guys run different front to rear offsets. Should be OK w/ the drivetrain from what Ive read. (Diff width or circumference tires is a bad deal)
Old Jan 14, 2013 | 01:42 PM
skevo8's Avatar
OK so as long as i have the same size tires all around there shouldnt be a problem right? its only if i run different size tires.
Old Jan 14, 2013 | 01:43 PM
skevo8's Avatar
its a 9. and can you post some pics of your car by any chance so i can see it. thanks
Old Jan 14, 2013 | 02:26 PM
skevo8's Avatar
what size tires do you guys recommend instead of the 245? maybe 225/40r18
Old Jan 14, 2013 | 02:36 PM
skevo8's Avatar
Old Jan 14, 2013 | 02:43 PM
skevo8's Avatar
^^ second pic 0 offset up front
Old Jan 14, 2013 | 05:25 PM
Hey, Im just a guy thats been on the EVOM boards for a few years & I run an aggressive wheel/tire set-up
I think you have made a mistake in mounting this set-up.
Sure a number of guys run diff offsets from front to rear & they report that it is OK. Personally I wouldnt do it
+0/+15 really dont work at all. +22 is very tough to make work. Even wide body EVO's dont run +0
See this pic. This is a 275/40/17 mounted on a +29. This set-up takes approx 8 hours of labor to make it fit correctly. If you cant stroke the rear susp like this then it just doesnt fit
Old Jan 14, 2013 | 06:10 PM
skevo8's Avatar
Thank you for your Input I really appreciate it. Looks like I'm just going to sale this set up for someone who really wants it. I did as much research as possible and came to the conclusion tht I would have to run 225 in the rear and a some what aggressive amber to make it work correctly. And I just don't want that. I want to be able to set up where I can take them off slap my drag radials on and race with out have if to do any crazy corrections.
Old Jan 14, 2013 | 09:58 PM
llDemonll's Avatar
18x9 or 9.5 and a +30 offset is a pretty safe offset for wheels on evo's. i believe those fit with 255's and a fender roll (just to be safe) but don't need pulling. i'm not a fitment guru though so this could be completely wrong
luvboost
Jun 5, 2026 03:44 PM
foreignf
For Sale - Wheels / Tires
14
Mar 8, 2012 04:49 PM
RevMoto
Aug 20, 2011 07:06 PM
Jason
Jun 15, 2011 09:13 AM
llvllattp
Nov 28, 2009 07:11 PM
