Is my DD brake choice a good one?
Hey guys, I'm about to re-do the brakes on the Evo and I need your input on my brake choice. I have done some research and well, what i've learned is that generally, you choose a brake set up that works for your needs. I do not track my car and I don't plan to in the near future simply because I can't afford it, nor do I have the time. I only drive to school, to work, to the mall and such places.
I have read SmikeEvo's thread on brakes and decided upon the following:
1. Centric Premium Front Brake Rotors
2. Centric Premium Rear Brake Rotors
3. Stoptech street performance pads
4. techna-fit stainless steel brake line kit
SmikeEvo's thread on brakes was posted in 2008. There might be better products (rotors, pads etc.) on the market right now, so please let me know what you think or advise me on what's better. I would like to maintain or better the stock set up.
thats almost what i have now. i just received my Stoptech Pads so those will be going in sometime soon. but i also have the Techna fit lines and i have a set of rotorpros slotted rotors. i currently have a set of Satisfied GS6 pads installed and they were real good on the street. now im going to try the Stop techs.
Thanks for your input guys. I'll go ahead with this set up.
Yea, the selling point was the price and quality, plus there are good reviews on it.
Your set up sounds nice. I like how the slotted rotors look to be honest but the 2 things which have deterred me from getting them are:
1. I won't utilize the slots because the brakes don't heat up enough on the street to release the built up gases.
2. Can't turn the slotted rotors if the need arises later down the road.
They aren't worn out but i'm doing an entire fluid flush and change on the car. So while i'm already on it doing that, I might as well right? Plus the guys at MAP gave me awesome pricing on it so i'll just get it anyways to reduce the squishy pedal feel.
That's great news knowing that the set up also can work for auto-xing.
1 Post
Stoptech FTW. Well balanced for most situations / applications. The only downside to the 309 pads is in cold weather. The first stop experience may leave you breathless. Once they heat up you are golden
Brake dust level is respectable as well.
Stainless steel brake lines are a wear item. Dirt will eventually work it's way between the stainless steel braid and the inner teflon line, and with enough movement over time this will cause a leak.
From what I recall, the techna-fit lines have a PVC outer cover to inhibit this process, but I would still replace them after 4-5 years. Or just stick with the hassle-free OEM lines.
Smike
626
Dec 15, 2021 09:03 AM
Smike
63
Apr 29, 2019 07:27 AM
Massimo Power
Evo 'For Sale' Suspension / Brakes / Handling
Oct 29, 2008 10:16 AM
