Rotor suggestion
Old Mar 26, 2013 | 05:32 PM
Viegasjuice's Avatar
Rotor suggestion
Need help everyone!! Im gonna replace these old beat up stock rotors. Im looking at the brembo drilled rotors from lancershop or the stoptech aero set. Which is a beter choice and if theres other suggestions please chime in. I need something affordable, not a big brembo brake kit. Thanks in advance
Old Mar 26, 2013 | 05:37 PM
ctfpevoVIII's Avatar
I like the DBA 5000 series but there a bit pricey but I think the DBA 4000 series is a little cheaper or the giro disc , either of these in the slotted version . I think lancershop may carry these still.
Old Mar 26, 2013 | 05:40 PM
jvlazzar's Avatar
what is your application?
for a daily driver with basic requirements, RotorPros or PowerSlot blanks should be fine.
if you're looking to spend more money or track you car, Girodisc 2-Piece.
Old Mar 26, 2013 | 05:45 PM
Street car, looking for something affordable. How do you guys feel about the ones i suggested. Also see the dba 4000 series drilled and slotted set, how are those?
Old Mar 26, 2013 | 05:51 PM
Well I don't think the ones you mentioned are bad, there brembos but I prefer the DBA's. There great rotors and used in many racing events but still very good for a street car when paired up with a good street pad. I personally like the slotted but drilled /slotted look nice also. The DBA's are only $50 more then the Brembos I think. I run the DBA 4000 on my 335 xi and there great. When my evo's stocks go I know what rotors I'm buying next.
Old Mar 26, 2013 | 05:58 PM
Would you consider them better than the brembos, an whats the diff between slotted and drilled/slotted?
Old Mar 26, 2013 | 06:08 PM
In my opinion yes. I would do a little research on the DBA's. I have never heard any negative feedback on them. As far as slotted vs drilled /slotted theres not much difference. The purpose of the holes and slots are to release gases that form when your brakes get super hot and it allows the pad to come in contact with the rotor. I like the slotted because theres still a lot of material. If you do slotted/drilled thats more material removed from the rotor. You would be fine with either for your application.
Old Mar 26, 2013 | 06:17 PM
I know what im going with. I appreciate the help. Thanks!!
Old Mar 26, 2013 | 06:26 PM
blkmkIII's Avatar
Get your stock rotors cut. $60... all done. Next!
Old Mar 26, 2013 | 08:25 PM
Ramen_Noodle's Avatar
Or, if you want to purchase brand new, why not get blank rotors? Affordable is $150 before S&H/taxes for all four rotors from KNS Brakes.
Old Mar 26, 2013 | 08:32 PM
BEKevo's Avatar
You'll be surprised how long the stock rotors will last.. Check to see if your within spec and just get them cut or "turned". Save a few bucks for better brake pads.
If you're daily driving the vehicle, I'd suggest cheap blanks. You want more pad surface area for a better bite, or if you need cooling get brake ducts.. Far more efficient.
Centric Rotors with the black finish are nice (same rotors used for the Stoptechs, just with slots). I've had the DBA 4000 series for a couple months and they're great. But I'd only recommend them if your tracking or autox'ing your car. Kinda overkill for a DD
Old Mar 27, 2013 | 05:24 AM
cs82685's Avatar
D
Truth, my stockers are still going strong as far as life although I do need to get them turned, I've got 105k on them.
Old Mar 27, 2013 | 05:30 AM
SaulHudson's Avatar
Centric blanks are nice rotors.
Old Mar 27, 2013 | 05:31 AM
EvoXnj's Avatar
i just picked up a set of rotorpros and like them. Im only using my X for DD so they do the job and at a descent price
Old Mar 27, 2013 | 10:10 AM
BEKevo's Avatar
that's impressive
