ordering new bilstein struts but have a question about installation.
would I need to order any hardware or bolts for this installation? I just want to make sure everything goes smoothly and not deal with any sudden headaches.
if you still have the hats then you shouldn't need anything.... the strut comes pretty complete...
why you getting new ones? you know bilstein rebuilds struts... unless you are currently sitting on kyb's...
also don't get oem struts. buy biltein HD's not only do they perform better then oem but they cost like 1/4 as much...
hope this has been helpful
oh, ok. Awesome. but yeah, I'm actually getting some bilstein hd's. Thanks, bro.
Like above post, check their site. I believe there's a Bilstein in NC also rebuilds. You can request for HD specs, or any spec you want.
Make sure the hole in the top hat lines up with the hole in the bottom dish of the strut or your springs will pop and bang and u gotta do everything over again. Check out the hotchkis spring install its very complete
so, you think I'd be better off ordering a new set of oem camber bolts just in case? anyone have the part # for the front passenger side camber bolts?
You could just loosen the bolts first and see if it comes out easily before attempting the entire swap. I helped a friend swap his setup out today. After 100k miles, his cam out with no issues. It's kinda random I guess, but its better to expect the worst.
why are you looking to replace them?
if you wanna throw away some money I will take some lol
I'm where they use salt in winter and mine are fine
you live in flordia I doubt yours are even rusted at all
NocturnalEVO
Mar 22, 2005 10:01 AM
