Weird Popping Noise
Old Apr 19, 2013 | 09:15 PM
Grummick33's Avatar
Question Weird Popping Noise
So a couple weeks ago i started noticing a popping noise coming out what seems to be the front drivers side of the car when I turned left. I thought it was the cv joints and noticed the boots weren't cracked but they were worn so I replaced them but the noise came back about a day later, and then I started to notice that it happened if I hit a rough patch of road or when i was breaking coming off of an offramp. I checked my tie rods and wheel bearings and they seem fine so I'm assuming that it's a bad strut but I wanted to get some opinions before I go out and buy an new set of coil overs. The car has about 100k miles on it and it is the oem strut.
Old Apr 19, 2013 | 09:34 PM
shrtstuff89's Avatar
get up under it and just compare passenger to drive side. make sure theres no missing bolts, washers, pins, any leaks or cracks.
Old Apr 20, 2013 | 10:41 AM
matrho2792's Avatar
Could always pull the wheel and check to make sure the strut isn't leaking.
Old Apr 20, 2013 | 11:12 AM
Grummick33's Avatar
So i pulled the wheel and the strut seems like it is barely leaking
Old Apr 24, 2013 | 07:26 AM
seanjohn291's Avatar
I'm actually starting to experience this as well.
Started yesterday and noticed that my passenger wheel well had cracked and is rubbing on the wheel so I believe thats what causing it.
Did you look any more into this?
Old Apr 29, 2013 | 04:01 PM
12WWGSR91's Avatar
My 03 is doing the samething when turning left, its like a knuckle popping sound. Like shifting around... in for some answers.
Old Apr 29, 2013 | 06:14 PM
kanovic's Avatar
Mine did the same thing and it drove me ape ****. Replaced ball joint axle seemed fine and everything. Anyway the problem was my strut and top hat. At first i didnt think it was the strut because if i hit a big pot hole i wont hear anything but the smallest stuff it would pop. I would check there.
Old Apr 30, 2013 | 10:23 AM
12WWGSR91's Avatar
Did you replace your joint axle or only the strut?
Old Apr 30, 2013 | 03:17 PM
kanovic's Avatar
The joint was perfect. Just replaced the strut and the top hat and rode a thousand times better with no noise.
Old Apr 30, 2013 | 05:40 PM
MRLancer05's Avatar
+1
I had a similar sound, and it was only when you drove over slightly uneven pavement. I replaced struts and top hats and the 95% of the noise went away, the other 5% went away when I replaced the sway bar end links.
Old May 1, 2013 | 12:43 PM
trubo's Avatar
I just picked up an IX and its doing the same thing, passenger side front. I inspected the whole front suspension expecting to find a broken end link or tie rod loose. I am thinking its the top hat. 73k miles. Where can i get just a top hat?
Old May 1, 2013 | 01:10 PM
x187's Avatar
I'm also experiencing this. Is there any way you can see from the outside if the top hat is the problem?
Old May 1, 2013 | 02:51 PM
WRC-LVR's Avatar
Mitsubishiparts.net ask for richard
Old May 1, 2013 | 06:41 PM
kanovic's Avatar
Mine was weird i could try to move the car back and forth and nothing. You could move the strut a little while the car was in the air with the wheels off. Mechanic replaced the strut and top had with one of his and it went completed away. But there was nothing i could see that lead me to the strut besides replacing the ball joint and my cv axle was perfect so i had no clue what else could be it besides that.
Jim3142
23
Jul 22, 2016 07:49 PM
dustin11
Dec 23, 2014 09:01 AM
Uryelowducky
Pacific Northwest
13
Feb 10, 2013 01:00 PM
DaJackson
15
Mar 5, 2011 08:23 PM
EvoHead7
Jul 13, 2010 08:05 PM
