Need help....rear upper control arm replacement
I have an 04 evo and the driver side rear upper control arm went bad. This was discovered at my inspection today. I found an oem replacement....but should I do both. If I should why?
Also is it worth getting aftermarket replacements? I could not seem to find them online just the bushings.
Any help would be greatly appreciated. Thank you
If you replace the bushings on the bushing with shaft ( whiteline superPro ralliart or whatever) you must replace them on both arms for that reason. You may need to go slightly stiffer in spring rate as well.
What is wrong with the arm and how did they discover it ? Are the bushings torn? Loose? ball joint bad ? If they are just saying that one bushing is seized, that would be incorrect as , like i said they are bonded from the factory. If the ball joint is bad, you have to get a replacement arm. If the replacement one is used, check the play on the ball joint...there should not be any at all. If there is , the only fix is to get new ones ( yes if that was the case then 2 new ones from Mitsu. )
I had trouble with passenger side rear trailing arm...the ball joint went bad and clunked everytime I went over bumps. That ball joint also is not replaceable so ended up sourcing 2 replacement arms that the joints were in good shape, replaced the dust boots, installed ES trailing arm bushings and all was well again.
Hope this helps you out
Be aware that one of those bushings is bonded to the shaft that goes thru it. This is done intentionally by Mitsu. It acts as a spring in rotation to both limit the travel for geometry reasons and help stiffen the rear in spring rate. The other bushing is replaceable and simply has a pivot bolt going thru it.
When you say trailing arm, are you talking about the one connected to the lower ball joint. I have a damn noise in the rear that is driving me mad. It sounds like something broke in the diff but it only make the noise at low speeds and going through bumpy uneven parking lots or when I hit the brake. I can get on the high way and do 80+ for 25-30 minutes straight with no issue so I'm not thinking its in the diff.
Mine used to make the clunk going over small bumps at low speed ( clunk rattle ), backing out of my garage etc, then it started getting worse and ended up that you could feel it clunking over minor bumps when turning left ( loaded up the passenger side arm that way ) little scary i hafta say to feel the rear suspension moving and rattling as it loads up
Only way to diagnose is a big bar to move it around... And that clunk rattle will drive you nuts
Bad enough wear could make the joint fail so bear that in mind.See my post about the joint not being replaceable. Def better to replace in pairs, so either get 2 new ones or make sure 2 used ones are in great shape. Mitsubishiparts.net will sell the joint boots to you so if they are punctured or torn, ask RussellM and he'll take care of it for you.
Hope this helps
The rear trailing arms are sort of banana shaped. Yes ....ball joint on one end and goes from axle hub to the body mounts in front of the rear tires.
Hope this helps
Hope this helps
Anyways, you say to replace in pairs, are you talking about driver and passenger or upper and lower? I'm just going to do the one for now because Ill most likely buy it knew and they aren't cheap.
To the op, thank for starting this thread, that dang noise was stressin me out.
hispanicpanic
Aug 13, 2016 02:04 PM
driftnburn
Apr 8, 2016 06:02 AM
hozej
Apr 11, 2014 12:37 PM
SilentCool
Dec 22, 2013 02:11 AM
