Side to Side play on the rear wheel
Hi
Recently, the car making that whirring noise on the rear. I thought the wheel bearing cause the noise; However, after replacing right rear wheel bearing, there's still a side side play on the wheel. Would please tell what cause it? My mechanic friend told me that the upper rear toe arm is culprit. What do you think about his suggestion?
Thanks
Thanks
You should have a friend look at the ball joing movement while you shake it... Or just grab em with a big pair of channel locks and clamp down on each joint... You'll feel each bad one click... You might also look the bushings... If you see a bushing and the bolt looks off center that one is shot... Or it there is obivous cracking then yea..
I rock the wheel, and he saw the assist link arm joint moving and also the bushing behind it. So my question is which is culprit that cause the movement? Is it the ball joint or is it the bushing? If it is the ball joint, can i replace it?
Thanks
Thanks
I had some noise coming from the rear, I thought it was also a bearing. It turns out it was worn out control arm bushings. My movement was subtle, but it was more of an "in and out" type movement, not some much side to side.
I ended up replacing all the bushings on both sides because it was easy enough and I had it all apart.
Check out the bushings and see how they look.
Thanks
OEM my friend.
There is three all together and I believe two of them are actually spherical bearings, so replacing them with regular bushings would actually be a step backwards.
There is a lot of information on here regarding them. Search "rear control arm bushings" there's a bunch of good threads.
Update, my friend used a channel locks and clamp the ball joint on the rear toe link; then we found out that the wheel stop playing while he was clamping it down. So the damn ball joint on the rear toe link is going out. Any suggestion for the replacement part?
Thanks
There isnt an aftermarket part. You will have to get the OEM arm
i wonder, if this unit is the same as the stock one?
http://www.lancershop.com/customer/p...cat=105&page=1
Look for excellent condition take-offs first and insist that there be no play on the ball joint.
WRC-LVR
Jul 1, 2012 07:12 AM
