Best Coilover/Suspension for IX
Id rather run AST4100s or AMR coilovers than the PSS9s.
I haven't seen anyone give a consistent review of PSS9s much less anyone who has actually run on them along with Ohlins, ASTs or KWs. You can google them and look up reviews from other vehicles. Not very many Evos run them.
I can't even compare them to the MR Bilsteins since I did all of my other suspension modifications at the same time as the coilovers along with a lower profile/much wider tire...
They are only $125 a corner for a rebuild/revalve and you can get them valved any way you want through Bilstein US. Last I heard, Ohlins were $250 to get revalved through Ohlins. So, get your spring rate right the first time if you get Ohlins.
Personally, valving on full bypass for street driving is fairly soft but I still feel every line in the interstate (note: full set of poly bushings, Perrin PSRS, Whiteline, RCA, Megan rear toe arm which uses a spherical bushing, Ciro Caster/Camber paltes which use a spherical bushing on top and 285/30/18 lower profile tires). I have the fronts with increased rebound&compression per adjustment over nomal valving with an additional increase in compression over rebound per adjustment. During tracking, I have front on no bypass and rears dialed back a little. I really prefer running with the rear of the car settling and the car pushing a little than it being squirley in the back (note: upgraded rear diff plates). I tried with the rear on full but I didn't like how it felt and dialed it back down.
Hiboost
75
Dec 4, 2019 05:09 PM
GTWORX.com
402
Dec 17, 2018 10:31 AM
Sonic Motor
EvoX 'For Sale' Suspension / Brakes / Handling
33
Sep 9, 2014 12:28 PM
THmotorsports
689
Jan 22, 2014 08:24 AM
twkwan
12
Jul 4, 2003 05:44 AM
