Removing calipers and lines question. (Quick one).
Old Jun 23, 2013 | 05:59 PM
AndyCT9W's Avatar
Right, I did search but didn't get any specifics on this question.
When completely removing the calipers from the car, is there a valve that closes to stop the loss/spill of brake fluid?
If so, is it at the caliper or the other end of the line?
Yup, newb question I know.
Old Jun 23, 2013 | 07:33 PM
killerpenguin21's Avatar
no, it will slowly drip out. i typically tape some paper towel around the end of the line, but i recently got a tip that you can pick up a valve stem from an autoparts store and shove it in there.
Old Jun 23, 2013 | 08:44 PM
AndyCT9W's Avatar
Cool, thanks for the answer. That's a bit of a shame, my 1985 MR2 has a valve that closes at the car end of the brake line so it doesn't leak.
Old Jun 23, 2013 | 08:52 PM
it doesnt leak a ton. just a slow drip last time i did it.
Old Jun 24, 2013 | 08:28 AM
Raptord's Avatar
I use a tire valve stem to plug the hole. It's just the right size.
Old Jun 24, 2013 | 09:37 AM
cfdfireman1's Avatar
^this^ fits perfect and totally stops fluid loss.
Old Jun 24, 2013 | 09:42 AM
heel2toe's Avatar
You'd think more cars would have a similar setup. Not so much for R&R brake lines but rather as a safety precaution in case a line were to rupture you would only lose one brake instead of all 4. I could see this being extremely useful on a track car.
Old Jun 29, 2013 | 09:49 PM
AndyCT9W's Avatar
Right, all the calipers are off and the valve stems are doing their job, thanks for the tip guys!
Old Jun 29, 2013 | 10:02 PM
yeah i just did the valve stem trick the other night...it was one of the laugh at myself about how i never thought of that before situations lol.
Old Jun 30, 2013 | 04:58 AM
deylag's Avatar
Learn something new everyday. I wish I did this when I took all my calipers off.
Old Jun 30, 2013 | 10:05 AM
I wouldn't want this setup
modern braking system have 2 separate circuits left front right rear & left rear right front. You never lose all brakes. A manual valve in a brake line can only lead to problems.
Wapoosh
Apr 4, 2015 05:36 AM
ImsoevoX
Evo X How Tos / Installations
20
Feb 11, 2013 10:50 AM
SparkTech
26
Dec 9, 2011 09:10 AM
revvin9k
Feb 14, 2010 09:30 AM
truDriver
Jul 3, 2007 06:15 AM
