Spring Rate Chart
Old Mar 27, 2004 | 12:36 PM
  #61
Evo Ate's Avatar
Back to Jason8's question, can anyone comment on the ride quality, performance increase/decrease, amount of camber correction and how the stock struts will last with the Eibach springs???? Thanks
Old Mar 28, 2004 | 06:11 PM
  #62
jemm's Avatar
Tein Basic .... 7/392(front).... 6/336 (rear)
Old Mar 30, 2004 | 09:35 PM
  #63
Bom's Evo's Avatar
Originally posted by timzcat
After getting my springs on my front camber is at 1.6 per side.
I don't know if I want that much because of tire wear issues and I do not autocross the car. Does anyone know if the Cusco Plates work with the stock struts and are there any opinion on the how much camber one could get away with with out having excess tire wear on the inside.
an alignment can't fix that???
how are those springs on our fine NJ roads?? and how does it handle now??? i really like those specs to the RSR titaniums..though it seems alittle aggressive for stock shocks..
Old Apr 2, 2004 | 04:05 PM
  #64
JT-KGY's Avatar
Is the ralliart spring info correct???
http://www.japanparts.com/shop/shop....ird=Suspension
they list two different types of spring for EVO8
Old Apr 2, 2004 | 04:07 PM
  #65
JT-KGY's Avatar
I just saw ralliart's pricing... it's nearly double from the Tein's
S-techs..... ouch
Old Apr 2, 2004 | 09:46 PM
  #66
Tri-Bar's Avatar
One set of Ralliart springs are for the Coilovers the other set is for the Domestic setup that you can buy with out the struts and shocks.
Old Apr 5, 2004 | 09:13 AM
  #67
EVONation's Avatar
WHAT IS GOOD SPRING RATE?
rate is 400 lbs front and 350 lbs rear is this???
Old Apr 5, 2004 | 09:26 AM
  #68
Tri-Bar's Avatar
What do you want to use your car for ? Springs over 350lbs are better for smooth roads/track. For the street. 250- 300lbs front and 300-350lbs rear would be a good start. Any higher and you will need to go coilovers. The stock sturts and shock wont like them any higher. You go for soft spring and bigger sway bars if you need a good street set up.
Old Apr 9, 2004 | 09:28 AM
  #69
Shahul X's Avatar
I havent heared of anything on the RSR titaniums... any info...and how much do they run?
-shahul
Old Apr 9, 2004 | 02:37 PM
  #70
Tak555's Avatar
is there any other vendors who sell the ralliart springs?
Old Apr 11, 2004 | 06:17 AM
  #71
hueman's Avatar
we can get the ralliart springs without the corresponding struts/shocks they offer? is that going to work just as well?
and yes, i'd like to find out who a vendor is as well for the ralliarts...
Old Apr 11, 2004 | 10:02 AM
  #72
JustDSM's Avatar
Tri-Bar,
I've emailed Tien USA and they've confirmed they H and S-Tech's are progressive rate.
Old Apr 11, 2004 | 01:49 PM
  #73
Tri-Bar's Avatar
Thanks, Updated
Old Apr 11, 2004 | 06:05 PM
  #74
Vroompsh's Avatar
hey guys, noob here. I want to lower my car mainly for appearance and ride quality. I wouldnt mind better handling out of some different springs, but i heard that mitsubishi is very strict on their warranty. Will Ralliart springs void the warranty of the car? also, which spring do you suggest to get that will make the sotck struts last the longest?
thanks
Old Apr 11, 2004 | 06:08 PM
  #75
Vroompsh's Avatar
hey guys, noob here. I want to lower my car mainly for appearance and ride quality. I wouldnt mind better handling out of some different springs, but i heard that mitsubishi is very strict on their warranty. Will Ralliart springs void the warranty? Also, which spring do you suggest to get that will make the stock struts last the longest? Jemm, what springs did you have on your evo 7?
thanks
