Brake Squeak When Turning
Old Aug 8, 2013 | 10:02 PM
Lag is Free's Avatar
I know, I know... another thread about brake squeak! Please, bare with me on this as I can't find any other threads with this particular problem.
I just installed a brand new pair of Hawk HPS street pads, which I'm in love with... the stopping power has been giving me wetdreams. Although, I have been left with a major problem. So, the issue is I have very little to no squeak when stopping in a straight line. This, however changes drastically whenever I turn the wheel coming up to a turn, or light braking around a slight curve. Are there any indications of what this might be? My only guess is the pistons are pressing unevenly and it might just be something I have to live with (even though I really don't want too) -- Tomorrow I'm going to take off my calipers to spray them with my air compressor and add more grease to the shims. I'd like to add that I also just had the rotors (which are slotted, not sure if that matters) turned about a month ago, when I had the old pads on.
Is there anyone else with a similar problem that has a solution? Again, I apologize because I know this topic has been beaten into the dirt, I'm just at my wits end with this issue.
Old Aug 12, 2013 | 08:26 PM
fantrman's Avatar
Check you wheel bearings for play. A slight wobbly bearing will allow the rotor to move slightly in the caliper and allow slight contact with the pad, causing noise. To test, put both hands on the top of your wheel and try to rock the wheel side to side. If you feel any play, your wheel bearing is warn. Good luck man
Old Aug 14, 2013 | 12:11 AM
Hey, thanks for the advice man!! I just ended up tearing my front brake calipers apart, cleaning them, then got anti-sieze and put it in the corners where the pads come in contact with the caliper. I also installed freshly turned rotors and did not bed them in this time around (I've never bedded in pads, till the Hawks... and I've never had any issues in the past)... so far so good. I've been driving for about three days now without an ounce of noise. My best guess is the calipers were extremely clogged and didn't want to move correctly.
TxFAkuma
45
Feb 24, 2017 05:19 AM
black ralliart
Jan 17, 2017 11:30 AM
va1k0s
May 31, 2016 10:36 AM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
ilovebowbies
May 17, 2016 08:50 PM
