Front left brake vibrations
Old Nov 24, 2013 | 07:43 PM
Socaloc's Avatar
Just installed posi quiet brake pads x4 and centeric rotors x4 as well. And i did the bedding procedures and lubing procedures as directed by the manufacture. As I begin to engage the brake to come to a stop at any speed it squeals like nails on a chalkboard on the front left side. Took both front tires off and i found the brakes like this,(see below) is that wrong or right and doesnt even matter. (Refering to the metal thing in between the pads.
Old Nov 25, 2013 | 10:34 AM
MechTech's Avatar
The metal shim should not be cocked like that. It should be straight up and down. Yes that can cause brake noise. Whether or not that is your issue, who knows. Remove and reinstall it then see what happens.
Old Nov 25, 2013 | 10:59 PM
itsmekai's Avatar
How loose is that shim, can you move it around with your hand? The tension on it should be high enough that it shouldn't have a problem sitting vertical.
The vibration must be something else not install correctly, especially if those are brand new pads and rotors. You could try brake bedding: http://www.zeckhausen.com/bedding_in_brakes.htm
Old Nov 26, 2013 | 07:12 PM
Socaloc's Avatar
So my front driver side caliper might be defective. Borrowing one to see if the noise goes away a d ways swap the front pads from left to right and vice versus. Just wanted to give a shout out to RRE for helping me out thus evening last minute.
Old Nov 26, 2013 | 07:16 PM
Socaloc's Avatar
Also wanted to add I had RRE bed them in again and still vibrates, im going to try bedding them again myself.
Old Nov 29, 2013 | 02:50 PM
Socaloc's Avatar
Issue finally figured out horrible pads from centric, getting a refund one way or another, the pads also cause minor defects into my new rotors.
Old Dec 2, 2013 | 08:14 PM
itsmekai's Avatar
Damn that sucks, did you end up swapping in another set of pad (or the old ones)?
Abacus
Apr 3, 2022 10:12 AM
Abacus
Jul 3, 2019 01:50 PM
Abacus
Mar 21, 2017 07:10 AM
Rob_STI_PNW
Northwest Region
Feb 22, 2016 07:54 PM
Abacus
Feb 10, 2016 10:59 AM
