Anybody run Ohlins Stage 1 sports??
I talked to WORKS a while back and was told these were discontinued. I still see vendors having these on their website.
http://www.maperformance.com/ohlins-...i-evo-8-9.html
MAP put these on their website not too long ago it seems, so I guess they are still available
These seem like a good upgrade before stepping up to coilovers, although not the cheapest upgrade from the oem bilsteins. Anyone have feedback on these? Are these worth it or better off to pay a bit extra for the Road and Track c/o?
Tommi....IIRC from back in the day the valving on these is better than the Bilsteins. they are not height adjustable at all so keep that in mind. Aslo IIRc the adjuster is on the bottom of the strut, not fun on the fronts but I could be wrong.. the adjustment is single only ( rebound IIRC ) Much like the Koni yellows although the valving might be better on the Ohlins.
It would be interesting to see what these did with the Swift spec-R Not sure that was done back in the day.
For $1900, you are only $600-$700 away from a set of Ohlins R&T. Also, if you don't have them already, a set of camber plates would add anywhere from $300 to $450 to the $1900 while the R&T's already come with front camber plates. Makes more sense to grab the coilovers, especially if you were going to get a set eventually. As you probably know, you would be a bit limited in spring choices (regarding spring rate, length, diameter) if you went with the Stage 1 package, the R&T would offer a lot more flexibility if you ever wanted to change your setup a bit.
I have a set of the Sports that I've been meaning to sell for a few years now. WRC-LVR has it right, although my Ohlin DFV coilovers also have the adjuster on the bottom in the front (but in reality, the strut simply has the shock mounted inverted, from what I'm told, so it really is on the top...). WORKS was pretty secretive about the Ride spring rate at the time when I bought them. Anybody ever hear if they revealed that? Kind of like the JFK assassination files at this point - I think that info can safely be released. I plan on listing mine someday for $900. Pics are at https://www.flickr.com/photos/ejevo8...7609837842633/
Agreed once you add the cost of camber plates the price gets close to the Road and Tracks. But with the increased available adjustability comes the process of tuning and dialing it all in. The Stage 1 seems nice because its an improvement over the oem Bilstein or KYB , while still being a plug and play.
After a few years of tracking the evo with this setup, I feel like Im at the point where Im ready for something better than what my kyb/Robispec combo can provide, but not sure Im ready for something like JRZ or Motons.
The adjustability and fine tuning features are nice about coilovers, but not sure Im just quite ready to be messing around with that just yet. A top of the line fixed perch setup vs a basic level coilover is the way Im seeing the Stage1 ohlins compared to the Road and Tracks unless Im missing something.
This Stage 1 package doesn't seem 100% plug-n-play, as you will still need to adjust the rebound settings to your liking
In addition, when you feel like you're ready to step up to coilovers, who would you sell the Stage 1 kit to? There doesn't seem to be much of a market for OEM-styled dampers besides dirt cheap KYBs and reasonably priced MR/HD Bilsteins. The only people I could see buying the dampers would be people looking for an edge in auto-x running in the B Street class. Not trying to shoot you down or anything, just a little devil's advocate
maperformance
Evo 'For Sale' Suspension / Brakes / Handling
113
Jun 7, 2018 07:10 AM
nemsin
Jun 23, 2015 09:21 AM
Luffy
44
Jan 16, 2007 01:28 AM
