RPF1's questions
Old Aug 9, 2014 | 10:25 PM
(03evo08)'s Avatar
RPF1's questions
I'm currently running RPF1's on my evo 8. They are 18x10 +38. And tires are Dunlop Z2's at 265/35/18's. I've been having rubbing on the Inside of my rear driver side wheel. Also rubbing on the outside of the front passenger side tire. I am lowered on coilovers. I'm not sure if I should try raising the car up to ride higher or if I should replace my coilovers with a different brand.
Old Aug 10, 2014 | 12:09 AM
evobros's Avatar
In the rear you mine be hitting the LCA. Are you catching the front fender up front?
Off topic could you post pics please... I love rpf1 in 18x10+38
Old Aug 10, 2014 | 11:10 AM
RJones's Avatar
You need a 5mm spacer for the rear not to rub on the trailing arm.
Old Aug 10, 2014 | 12:37 PM
(03evo08)'s Avatar
Evo
That's it on coilovers. No in clearing the LCA's in rubbing a 5mm spacer in the rear so I can clear it. And the front I my rubbed at full turn, turning right.
Old Aug 10, 2014 | 12:38 PM
(03evo08)'s Avatar
Same car
Old Aug 16, 2014 | 06:20 PM
slowsrt4:('s Avatar
looks good, what spacers are you currently on?
Old Aug 18, 2014 | 06:46 AM
charlie.tunah's Avatar
I run the same wheel with a 285/30-18 ZII. 20mm spacer up front, 5mm spacer in the rear. No contact in the rear at trailing arm. Some liner contact up front on one side.
Brokeassevo
Aug 4, 2017 08:15 PM
MXRNick
16
Jul 17, 2017 06:05 AM
BluEvo62
Jun 6, 2017 08:41 PM
dk3Jdefje1X
Jan 3, 2017 10:20 AM
hkfeet
Jan 23, 2005 10:57 AM
