How can I fix under steer?
Old Oct 31, 2014 | 03:00 PM
Waffled's Avatar
Obviously I can just drive slower
So far I've put in coil overs and poly bushed the front.
What else can I do?
Old Oct 31, 2014 | 03:08 PM
xXANCHORMONXx's Avatar
Rear seat bar
Front splitter
Restack rear diff/ send to tre for 12 plate mod
Old Oct 31, 2014 | 03:14 PM
egis's Avatar
Have you tried adjust camber? Like -2 for the front and -1.5 for the rear? Ar least it's cheapest you can trie.
Old Oct 31, 2014 | 05:34 PM
kyoo's Avatar
https://www.evolutionm.net/forums/ve...cd-tuning.html
Old Oct 31, 2014 | 06:05 PM
Viegasjuice's Avatar
Tires/camber/bars.....I would also really look into the mechanical diffs.
Old Nov 1, 2014 | 04:16 PM
todd6027's Avatar
What else can I do?
make the rear stiffer
Old Nov 1, 2014 | 05:44 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Old Nov 1, 2014 | 06:43 PM
robbyredneck's Avatar
as stated. stiffer rear bar is the deal.
Old Nov 2, 2014 | 11:52 AM
todd6027's Avatar
have you had 4 wheel alignment done recently ????
Old Nov 2, 2014 | 12:03 PM
e_kobz's Avatar
A good place to start is to get a stiffer reay sway bar, run a higher spring rate in the rear tha the front, run a little more rear tire pressure, and a re-stacked rear diff. The new ACD ecu flashes supposedly work pretty well if you have a 05 VIII or a IX.
Old Nov 3, 2014 | 09:55 AM
luckybull's Avatar
Originally Posted by golgo13
Great Chart!
raising front tire pressure and lowering rear to increase oversteer seems backwards to me..
Old Nov 3, 2014 | 10:23 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Me too, but I googled it.
http://www.tirerack.com/tires/tirete....jsp?techid=58
Old Nov 3, 2014 | 10:46 AM
heel2toe's Avatar
It's funny bc I feel like I've seen that same charted posted prior and I had a similar comment and and just now as Im looking at it I thought the same exact thing...
For the most part that chart seems accurate but as reputable as a source that TR is I still disagree. From talking with other folks as well as my personal findings while racing my car throughout the past few years they have it backwards.
Old Nov 3, 2014 | 12:05 PM
GTWORX.com's Avatar
It's a little misleading. Really there's a sweet spot for tire pressure and going higher or lower will result in less grip. In general, a little too low will reduce grip more than a little too high.
- Andrew
Old Nov 3, 2014 | 01:16 PM
heel2toe's Avatar
Ahh that makes sense then.
However if you are trying to make small handling changes through tweaking the tire pressures and dropping the rears by like 2#'s yields more oversteer you are probably already way too low with the pressure in the first place.
